Old 11-27-2023, 10:06 PM   #1
tucsonjwt
Mystery Headlight Clips
I am replacing the headlights on my 83 C20 Silverado with quad headlights. There are 4 ciips attached to each headlight retainer screw (16 total) and they are very rusty. Does anyone know the purpose of these clips? I don't see them on other 83 Silverados.
tucsonjwt is offline   Reply With Quote
Old 11-27-2023, 10:47 PM   #2
Pontiac1976
Pontiac1976's Avatar
Re: Mystery Headlight Clips
Looks like the person used dash pad clips, bent drilled them. But I could be wrong.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 11-28-2023, 12:32 AM   #3
tucsonjwt
No, they are not dash pad clips - much smaller. They are about 5/16" wide and about 1.5" long. They appear to serve no purpose, other than to create rust spots in the area. At first I thought they had something to do with the headlight retainer bracket, but the brackets have their own screw holes to secure them to the headlight buckets. Maybe they are for some sort of covering that snaps on over the headlights, but I don't know why anyone would need that. They have been on the truck since I bought it in 2002.
Old 11-28-2023, 12:35 AM   #4
tucsonjwt
Or, maybe clips to hold on a full width bug screen with cutouts for the headlights and clips to hold the frame in place?
Old 11-28-2023, 08:52 PM   #5
1774btcrew
1774btcrew's Avatar
These were for a wire type rock guard. The guards came in chrome or black
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 12-02-2023, 07:05 PM   #6
kwmech
Yup, aftermarket rock guard holders
Old 12-02-2023, 08:52 PM   #7
dieseldawg142
dieseldawg142's Avatar
had a set of them on my old K5...there pretty much useless. whenever something hit them, the guards would get smacked into your headlights, them clips were pretty janky and would allow the wire to pop out and hit your lights.
little hard to see them
if you look close you can see the cross hatch on the lights
Size:  44.5 KBName:  $_57.jpg
dieseldawg142 is offline   Reply With Quote
Old 12-03-2023, 09:02 PM   #8
tucsonjwt
Thanks for the information. I can see how they could be a problem. I would think a full cattle guard on the front would be a better idea.
Old 12-04-2023, 01:37 AM   #9
farmall
farmall's Avatar
I use them on my Cibie Z Beams and Hella H4s. 35+ years and no problems.
1955 GMC 250 8 Flatbed
1971 C30 157" 350 4spd 10' Flatbed
81 GMC K30 CnC 9' Flatbed 454 T400
89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958
71 LT1 Convertible, 72 Coupe
69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2
farmall is offline   Reply With Quote
