![]() ![]() ![]() Join Date: Jan 2018
WTB: Clutch Setup
I've decided I want to swap my 81 over to a manual, so I need the clutch parts to make that happen.
I'm leaning towards using mechanical linkage instead of hydraulic because I already have a bellhousing that uses the mechanical linkage. I only have that bellhousing with a clutch fork, so I would need everything else. Pedals, linkage rods, z bar, and piece that mounts z bar to the frame. I wouldn't be against a hydraulic setup if the price is reasonable and it comes with the bellhousing that I would need too. Probably going to have to be something located within a couple hours of Canton, GA since the parts a fairly large.
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
![]() Join Date: Oct 2014
Re: WTB: Clutch Setup
I have a set of manual pedals but they came off a truck with hydro boost brakes. I'll have to check but I'm fairly certain I also have the z bar frame mount. $150 shipped.
Thanks for your offer, but I just found a thread confirming that the hydro and vacuum boosted trucks have different pedal ratios. I'll be sticking with the vacuum booster on it now, so that's what I need.
173.87 shipped.paypal or postal m.o a cepted.located and ships from NM.
Thanks y'all for the offers, I was able to find a set locally from a 77 cab for $60. Got everything except for the rod from the z-bar to the clutch fork.
