![]() Join Date: Feb 2003
interesting ,, my 71 has 72 doors from factory
has anyone else noticed that the late production blazers in 1971, june build has upgraded to the 1972 door panels and 72 pinch screws at the vents?
1971 K5 CST Blazer 1965 Chevelle Malibu 283 (sadly sold) 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
Re: interesting ,, my 71 has 72 doors from factory
I think they start releasing the new model in august if that’s correct i think that would be too early but I am no expert
of all my searching i cant find a 71 built any later than june 71. my june build has the original blue door sticker with the vin# and 72 doors.
Roadtrip!
In those days, sept. was the change over month. I think all of the blazer doors (70,71 and 72) all had a screw under the wing window. Not sure about 69. The earlier ones had a plastic escutcheon with the screw. I think it would be odd for a june 71 blazer to have 72 plastic door panels, but who knows for sure. Alot can happen in over 50years...
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Model change for us (Oshawa Assembly Plant) was always in late July right after summer shutdown.
Maybe OP's doors are not original, or GM decided to do a design change part way through model year. We did this quite often. Would like to see pics of OP's Huey in his signature. Last edited by hemi43; 12-26-2023 at 07:54 PM. |
Too Dumb To Know Better
My 70 Jimmy was built in July, it had the screws for the vent windows.
#7 | |
the assembly plant in Stlouis was shorter of production.
![]() Join Date: Jul 2003
Please post pics of the doors preferably with both the door panels on and off. It's easy to tell if the doors have been modified to accept 1972 door panels.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... ![]() 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
pics below i seen the date of 6/71 before power washer hit it i will get pics of door panels soon
this is the correct vin on factory sticker
Yeah, that looks legit.
#13 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Can you post a photo of the screw just below the vent windows?
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#14 |
I can't comment specifically on these doors, but in general:
We would pull ahead minor changes in detail components if we thought nobody would notice, or if there was not a decrease in value, if the timing worked out and it was convenient to do so. That would be one more thing to not have to worry about when the bigger model change hit and we could cross it off our list. Things that were "marketable", like an appearance change (interior or exterior, like a new grille or front end appearance), that we could charge more for, or that were specifically tied to a new model via regulations would break point on the model year. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#15 | ||
will do tomorrow. Quote:
interesting thx for chiming in .
#16 |
Any updates?
#17 |
[QUOTE=1970cstblazer;9272712]Any updates?[/QU
OTE] i will take pic of door tomorrow.
#18 |
#19 |
Carpe manana
Bump for pics...
#20 |
pics keep flipping sideways i will try and fix it
#21 |
Carpe manana
Did the doors turn out correct for 71?
#22 |
they look to have 72 door guts and panels but are on the original 71 door so either it was dressed up with 72 guts and panels from factory or some one took the time and money to change both door guts and panels to over to 72 style not sure? ??????????
#23 |
it is a late june 71 build. the last month of the 71 build for the St Louis plant i belive. so it may have been one of the earliest to receive 72 panels and door guts ?? who knows?
#24 |
![]() Join Date: Dec 1999
As I see it, the most likely scenario is. In the past 50+ years someone has changed out hardware to accommodate the 72 door panels which they liked more.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
#25 |
I converted my 71 GMC K15 suburban to 72 door panels over 25 years ago.
Finding a good set of regulators for the front was fairly easy then, as they are the same as all pickups. Finding rear window regulators for the back windows was another story. After looking for some time, I finally took my original rear regulators drilled out rivets and replaced with longer 72 posts. about 6 months later I stripped a 72 suburban with proper long posts. Those regulators are still on the shelf. |
