Old 12-31-2023, 04:48 PM   #1
Nima
Blue 67
Can you identify there light inserts?!
Hi:
I picked up these fenders for $25 each since mine where totally damaged. The seller didn't know what kind of light insert these are since they were rivet in a piece of sheet metal! I like to know what lights may go in there just in case I like them and I want to keep them this way rather than patch them.
Thanks and happy new year.
1953 GMC 3/4 ton: current project
1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake
1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!!
1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive
1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project
2005 Silverado 2500, 4x4 Duramax, original owner
Nima is offline   Reply With Quote
Old 12-31-2023, 05:10 PM   #2
Getter-Done
Getter-Done's Avatar
Re: Can you identify there light inserts?!
On a visual search alot of ford stuff was showing up.
I am going to resize and then check it again.
It would not let me do it in my photo gallery.
Name:  53 fender.jpg
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 12-31-2023, 08:13 PM   #3
Nima
Blue 67
That is cool you can do that.
Old 12-31-2023, 08:20 PM   #4
Getter-Done
I have not found any matches.
If you click on the square in the Upper right corner,
(Visual Search)
Maybe your search will be different .
84 Chevy K-20
Old 01-01-2024, 11:37 AM   #5
dsraven
a little more info, like dimensions, may help. have you looked at the possibility that it may simply be a 6" oval stop turn tail light from a grote industries? the ones that mount into a rubber grommet and have a plug in pigtail, they are a sealed unit. then possibly the other holes were used to mount a stainless sheet metal trim part to dress up the area a bit. there are solid backed rubber grommets that would seal out the stuff that flys off the back wheel. anyway, maybe google the product for a quick dimension check of the hole size you have. lots of this style of light were/are being used on home built vehicles and trailers, there are stainless or chrome dress up parts for them as well.
Old 01-01-2024, 11:44 AM   #6
dsraven
mount with dimensions for the hole required
https://www.easternmarine.com/grote-...s-flange-43723
light that fits into the mount
https://www.easternmarine.com/grote-...ail-lamp-53962
Old 01-01-2024, 11:45 AM   #7
dsraven
another light option that also fits
https://www.amazon.com/Grote-54702-L.../dp/B00Q2FY9Z4
Old 01-01-2024, 03:32 PM   #8
mr48chev
mr48chev's Avatar
I'm thinking that that is a light off a later model truck. Could be car but I bet truck
My ongoing truck projects:
Old 01-01-2024, 03:47 PM   #9
mr48chev
mr48chev's Avatar
They may have mounted a light upside down.
Old 01-01-2024, 04:50 PM   #10
Nima
Blue 67
That is what I was thinking also.
Old 01-01-2024, 11:42 PM   #11
mr48chev
mr48chev's Avatar
Flipped to see what it looks like. I'd try a 73/80 something Chevy fleetside taillight just to see if it fit.
Old 01-01-2024, 11:44 PM   #12
dsraven
the first light I thought of was the 70's chevy truck fleetside box tail light
Old 01-02-2024, 12:31 AM   #13
leegreen
70s fleetside might be it. Maybe just the lens over top of the oval light like mr48chev suggested.
It sort of fits, allowing for paralax of original image
leegreen is offline   Reply With Quote
Old 01-02-2024, 12:32 AM   #14
leegreen
I did not check dimensions, just scaled an image of the lens to same size as opening
Old 01-02-2024, 01:09 AM   #15
mr48chev
mr48chev's Avatar
I'd say you can scratch that one off the list.
Old 01-02-2024, 10:37 AM   #16
greg_h
just a thought but with that curve, what about van taillights?
greg_h is offline   Reply With Quote
Old 01-02-2024, 10:54 AM   #17
Nima
Blue 67
I'll see if I can hit the local junkyards to see what might be available. Thanks for the info.
Old 01-02-2024, 11:05 PM   #18
mr48chev
mr48chev's Avatar
You might want to wrap a sheet of card stock aka old file folder around the light opening and trace it out and trim it so you have a pattern you can lay over potential lights. I'd be looking at mid 70's to around 90 as that kind of thing was a hot lick in the 70's, 80's and early 90's.
Old 01-03-2024, 01:13 AM   #19
Nima
Blue 67
Okay, it is not 80-90s taillight. The curvature does not look the same. 1980s taillight has equal curve or angle on either sides.
Old 01-03-2024, 01:09 PM   #20
57tailgater
Maybe contact this guy and he can identify the opening and what would fit: https://www.taillightking.com/index.htm
57tailgater is offline   Reply With Quote
