Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 12-31-2023, 07:14 PM   #1
PDW HOTRODS
PDW HOTRODS's Avatar
Check Engine Light
Does anyone here know if there is a way to program the ECU to never show the check engine light? I bought a 2010 Chevy that the CEL never comes on, not even when turning the key to the on position when all the other lights come on. I used a code reader and there were multiple codes that should have turned on the light. I am wondering if the car dealer disabled the CEL instead of fixing all the problems. Thanks.
PDW HOTRODS is offline   Reply With Quote
Old 01-01-2024, 03:49 AM   #2
EVRLET
EVRLET's Avatar
Re: Check Engine Light
Yes, you can tune out, via HP Tuners, DTCs that normally would trigger CELs.
Key on, no CEL is a new one though and I don’t think you can turn that off via computer programming.
Customization is what you want it to look like -- not what other people think it should look like
EVRLET is offline   Reply With Quote
Old 01-26-2024, 12:04 PM   #3
KShortell
KShortell's Avatar
I had a thought. Perhaps the bulb is burned out. This could particularly happen if the CEL had been on for a long time.
The unfortunate part is that these bulbs are not the twist to remove type that have been used in the past. They are soldered in, making replacement a bit more involved.
It certainly could be worth testing the bulb if you really want the functionality. If you don't like to fool with it yourself, Southern Electronics in Richmond, VA does really good work at an affordable price. Turnaround is fairly quick, too.
Good luck!
Semper Paratus
KShortell is offline   Reply With Quote
