01-02-2024, 12:55 PM | #1 |
Would you reuse this GM 10.5" 14 bolt differential carrier?
Pulled the bearings on the carrier and the mating surface doesn't look too pretty. Debating on cleaning it up and reusing it or ordering a new housing.
This was the worst bearing (other one was decent still). This is the surface I found under the bad bearing The other side was not bad but does have this nick on the surface
The square family: 1980 Chevy K20 Farm Truck 1977 Chevy K20 (resto project) 1978 Chevy C20 (future project?) 1978 Chevy C10 (parts) 1975 Chevy C10 (parts) |
01-02-2024, 01:27 PM | #2 |
Re: Would you reuse this GM 10.5" 14 bolt differential carrier?
I wouldn't reuse it if it were me. I wouldn't want to risk a failure while driving.
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
01-02-2024, 02:05 PM | #3 |
If that bearing is a press fit and doesn't spin on that surface, you can probably reuse it. If that surface sees motion, then replace.
Looks like sometime in the past, a bearing had a bad failure. Very possible this bearing has ran thousands of miles with that hidden damage. In any case, do a very good cleaning job on the axle insides to make sure any past bits of failed bearings are removed. Bits of past bearings might explain the damage on this bearing. |
01-02-2024, 02:11 PM | #4 |
Although it is not in perfect condition, if the bearing presses on tight it is safe to use. It's not going to go anywhere. Personally--I'd kinda frown, but I would use it
01-02-2024, 11:40 PM | #5 |
I'd be hearing phantom bearing howl every time I drove it if I reused it. Probably ok, but if you have it torn apart this far it may be worth calling a junkyard and getting a price on a used carrier as they're out there.
01-03-2024, 09:05 AM | #6 |
It looks like someone torched it off and got a tad deep. If that's the case, it wasn't a prior bearing doing becoming "heat fused" so it's probably fine to reuse. Having said that, beings you've already got it apart...
I may be old, but I still enjoy the feeling of the earth rotating beneath my wheels... |
01-04-2024, 09:35 PM | #7 |
as long as the bearing presses on tight I'd run it.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
01-05-2024, 05:55 PM | #8 |
If the bearing fits tight, run it. Some one was ham fisted getting a bearing off in its previous life.
01-06-2024, 01:32 PM | #9 |
Thanks for all the comments! I cleaned up the bearing surface as good as I could (forgot to take some pics of course) and pressed on the new bearings. Seems to have pressed on tight & is flush with the carrier.
01-09-2024, 10:26 PM | #10 |
Born Psycho
you will be fine, as was said earlier, someone torched off the old bearing and went a little too deep- i've done it myself a time or two but as long as the new bearing went on tight you're good to go.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
