Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 01-04-2024, 12:59 AM   #1
Getter-Done
Getter-Done's Avatar
Air Compressor / DIY. ?
I am thinking of building a Compressor at a shop, Where I have some of my Machine Tool Machines located.
I am going to try to use what I have,
And make it even Better without Creating another Huge Project.
I have a Very good compressor at my House.
I am trying to stay away from having a high dollar Compressor that I don't use much.
Here is my Idea for this location.
At this location the 2 compressor's that are there/
One is in sad shape,
But the tank is good and also has a good Vertical tank plumbed in.
The other one the Compressor is (Wore Out) and weak,
It still builds air but takes a LONG Time.
But the Tank is good , The Motor still runs, Will I Use that motor? Ytbd.
My first plan is to buy this.
Link: https://www.harborfreight.com/air-to...ump-59193.html
Then I will plumb the other tanks into it.
I will possibly have 1 of the tanks by my main machine inside the garage.
The other 2 tanks will be in the Air Compressor shed outside.
If the old Motor does not work out,
I will get this one.
Link: https://www.amazon.com/gp/product/B0...DKIKX0DER&th=1
Then a pulley from here.
Link: https://www.zoro.com/tb-woods-58-fix...58/i/G0948236/
I may need a new Pressure switch.
They are reasonably priced though.
Then the Icing on the cake.
I plan to run a Condenser /Water filter combo something like in the video below.
What do ya'll think?
It's not really about the price as much as using what I have that is still good.
84 Chevy K-20
Old 01-04-2024, 01:00 AM   #2
Getter-Done
Re: Air Compressor / DIY. ?
I will post some pictures of tanks when I go over there.
84 Chevy K-20
Old 01-07-2024, 10:48 AM   #3
AussieinNC
Moderator
AussieinNC's Avatar
Morning young man...
If it was my choice, I would not be looking to layout some $340 plus to try and save the old system...and wonder if the tanks are really that good....
Any reason why you need 3 HP ?
I have this unit in my shop and it works great, is mobile if necessary and its a reasonable price...
https://www.harborfreight.com/29-gal...sor-58507.html
Just my 2 cents worth...
Have a great year...
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 01-07-2024, 11:18 AM   #4
raggedjim
raggedjim's Avatar
And a differing opinion, I always try to reuse/repurpose as much as I can so I understand the motivation to use what you have.
I will throw this in though, I have a buddy who had his tank and compressor under a lean-to outside of his shop. A 60 gallon standup. He wasn't very good at draining the tank on a regular basis and one day he was in the shop and his compressor tank blew out the bottom, took off like a rocket, and broke one of the 2x6's of his lean-to.
Check out those tanks as well as you can.
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 01-07-2024, 11:24 AM   #5
Getter-Done
I actually looked at that compressor yesterday.
Yeah, The tanks not being as good as I think they are,
Has been on my mind.
Also Creating another project has been on my mind also.
I did find out the motor on the old one will work.
I still debating,
The compressor you posted will probably win .
84 Chevy K-20
Old 01-07-2024, 11:36 AM   #6
Getter-Done
That's a Very good Point.
I have checked 2 (as well as I can) of them and they checked okay .
The other one Still has the Big Motor and compressor on it so I can roll it around and shake it.
The new compressor that AussieinNC linked will probably win the contest.
Because that will eliminate another Project.
84 Chevy K-20
Old 01-07-2024, 11:44 AM   #7
Getter-Done
I was wondering about this for 2 reasons.
1st reason: This is what HF suggested.
2nd reason is a 5HP is cheaper. So, is More Better? In this case?
84 Chevy K-20
