![]() Join Date: Aug 2015
Roof Cutting
Hey
ive got a cab that is rough except the roof, got another cab that the roof is the bad part, tree fell on it has anybody taken a good roof off and put on another cab any suggestions to possibly speed up the process any tool suggestions, ive seen the thin line sanders, probably buy this weekend, but any other that anyone can think of yes i know , its going to be alot of spotweld cutting, lol Thanks
A Little Better Every Day Cancer Survivor, most dont know what they have until its gone, appreciate everything |
![]() Join Date: Jan 2015
Re: Roof Cutting
Are you replacing the whole thing or just the skin?
1965 C-10 1/2 ton shortbed part time daily driver 1980 C-10 1/2 ton shortbed project |
Re: Roof Cutting
hey
im replacing the inner and outer roof and the front outer windshield panel
Re: Roof Cutting
any foto s of the project s ?
dont want to hear excuses, i want to hear solution(s) |
Re: Roof Cutting
If it's a big back window. Cutting it at the pillars. Is probably the only thing. That will make it easier or faster.
Re: Roof Cutting
Here's the roof pictures, i know it;s alot of work, Aint Scared, lol
like most, more time than money and not alot of either
Re: Roof Cutting
inner roof pictures, might be able to hammer and dolly once the outer skin is off, probably use a headliner to hide the imperfections
![]() Join Date: Nov 2013
Re: Roof Cutting
No advice, but please take a lot of pictures of the process and post them here - it's hard to find good pictures of the inner structures of the roof.
Re: Roof Cutting
cheque for spot weld s n drill the out w a bit ( or you can buy a spot weld drill bit )
and double cheque before you peel the roof tha you can work your way down in seeing at what else needs to be replaced take plenty or foto s of before starting the job . so you ll have a reference or seeing at how it looked before the job was started i would start w the one your keeping in seeing at how far you need to pull things apart , imo than work on the one your stripping for part s s looks like a fun project , imo just some time involved in doing it tho
![]() Join Date: Dec 2009
Re: Roof Cutting
This type of drill for Spot weld works best for me.
Link: https://www.ebay.com/sch/i.html?_ssn....m3561.l161211
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
Re: Roof Cutting
I replaced my 61 roof skin with an aftermarket one. I cut the skin off then air chiseled what was left. Cleaned it up and used panel bond and glued the new skin on. Really wasn't bad, and the panel bond should seal it off.
Re: Roof Cutting
62C30
I Like your Style might try it that way, spent a couple hours last nite getting the old roof sealant off also Getter Done Thank You for the Link to the spot weld bits, ive ordered some
#13 |
Re: Roof Cutting
I do have some decent pictures of my 61 with the roof skin off if anyone needs anything. I had the skin off when it was blasted so I primed it and down the a pillars and anywhere else I could get before I glued the new skin on.
#14 |
Re: Roof Cutting
hey 62C30
Pretty much what i was going to do, my inner roof needs some love when i get the outer off but sure i can get it close, going to make a headliner, should be easy as i can drill and seal some aluminum slats in the inner for support and use them for support for thin wood liner that ill cover with something ill take whatever pictures you can share , just to use as a reference when i get the outer off Thank You
#15 |
Re: Roof Cutting
Here are some pictures. There was some rust in some of the bracing that I think they reproduce now.
#16 |
Re: Roof Cutting
ok
got my outer roof off, as expected its a mess underneath, i have cleaned up most of the loose rust and old soundproofing mats, i still think i can save the inner roof, going to take a little time with dolly and hammer and most likely cut and weld ill upload pictures after work
#17 |
Re: Roof Cutting
pictures
after the outer roof was off, i was able to work the inner to a decent point, im going to make a headliner so that should cover almost all of the imperfections Thanks
#18 |
Active Member
![]() Join Date: Sep 2023
Re: Roof Cutting
If you dont mind me asking, what glue did you use and where did you get it Thanks David
#19 |
Re: Roof Cutting
#20 |
Re: Roof Cutting
It's not cheap and you lose part of it in the tip but it seems to work well
#21 |
Active Member
Re: Roof Cutting
Thanks I have yet to see anything that was good to be cheap in the last few years. I bet it is cheaper in the long run. I am going to try it. I dont weld as good as I did a few years ago. Cant see or hold still lol
#22 |
Active Member
Re: Roof Cutting
The gun to use it is much higher than the Panel Bond on ebay
#23 |
Re: Roof Cutting
I think for the tips, gun and adhesive is was around $100 but it's been a few years. I've used it on several projects and so far has been great. It would bond different types of metal together and since there is no heat like welding no chance for warping or burning paint.
#24 |
Re: Roof Cutting
ok
after looking at the inner roof, i probably wont be happy with it so im looking at cutting it out, Has anyone done this, i know where the obvious spot welds are the upper door frame, across the windshield and across the back(only accessible after outer roof is out) Thanks
#25 |
Re: Roof Cutting
I replaced only the area above the windshield on the inside and out, not the whole thing. I think that panel for 64-66 is a newer part.
