Old 02-02-2024, 06:40 PM   #1
CarlsLQ9SS
CarlsLQ9SS's Avatar
Center caps
What center caps do I have? I just bought them and look to be NOS but not sure.
Carl
1971 GMC short bed, (Henry)
Options I've added, tilt, ac, 8k tach,
Electric speedometer conversion for LS swap,
6.0 with 823 heads and BTR stage 4 truck cam,
4L80e, posi with 3.73 rear end,
Power steering and power brakes
Lowered 5/7. Frame up build.
CarlsLQ9SS is offline   Reply With Quote
Old 02-03-2024, 03:56 AM   #2
lil hoodlum
lil hoodlum's Avatar
Re: Center caps
Just an edjucated guess, I would say those are 1967 - 1968 caps with out the paint. They also look like they might be for a C20, guessing by how deep they look on my computer screen. What is the overall diameter?
1968 C10 327, 3 speed manual, LWB stock height daily driver.
1968 C20 327, 4 speed manual, LWB stock height custom camper with heavy duty leaf springs rear, 50th anniversary edition. Hoping to press into daily drive status soon.
lil hoodlum is offline   Reply With Quote
Old 02-03-2024, 06:00 AM   #3
CarlsLQ9SS
CarlsLQ9SS's Avatar
Re: Center caps
10 3/4” outside to outside, 10 1/4” inside to inside and 2 5/8” deep
Carl
Old 02-03-2024, 08:45 AM   #4
Re: Center caps
What you have are hubcaps. Center caps are what are used on styled wheels. Lil hoodlum is correct. These are 67-68 C/10 hubcaps. The hubcaps for 20/30 series look from the from identical to the 10 series, same diameter. But those are different on the back due to having an inner ring used to accept the clips on the wheels for mounting
Old 02-03-2024, 08:53 AM   #5
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Center caps
Those are 1974-1990 Chevy car poverty caps, mostly used on police package Bel Airs, Impalas and Caprices..
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress...
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 02-03-2024, 12:15 PM   #6
CarlsLQ9SS
CarlsLQ9SS's Avatar
Re: Center caps
Thanks everyone for your replies and knowledge. I agree with 1970cstblazer, they are identical to the pictures you posted. I was thinking they was 67-68 hubcaps but my question is will they work on 68 Chevy truck wheel?
Carl
Old 02-03-2024, 12:41 PM   #7
1970cstblazer
I don't think those will work. They require the stamped nubs on the wheel to attach.
Old 02-04-2024, 11:16 PM   #8
cwcarpenter98
cwcarpenter98's Avatar
Re: Center caps
IF you have the stock nub style wheels, then yes, these will fit
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 02-05-2024, 07:40 AM   #9
Re: Center caps
These will work on 5 and 6 lug truck wheels the same as they work on car 5 on 4 3/4" wheels. The same is true for all Chevy car hubcaps that mount by nubs, which began in the early 50s.
'54 car caps on 5-lug truck wheels
Old 02-05-2024, 12:43 PM   #10
SCOTI
SCOTI's Avatar
Re: Center caps
Most passenger car & 1/2 ton truck caps are 10 1/4 ID & fit on both wheel pattern wheels (5x4.75" & 5x5").
Later 3/4 ton trucks utilize the larger 12" ID caps.
Early smaller trucks (chevy Luv) used a 9" cap.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-06-2024, 09:50 AM   #11
Re: Center caps
yep, that's the gospel there. The 9" are what you'd find on the 4-luggers like Corvair and Chevy II. On my trailer, which has 5 x 4 1/2" lug pattern, I have Mopar (which used the 9" caps) 15" wheels with LUV hubcaps
Old 02-06-2024, 06:04 PM   #12
michael bustamante
michael bustamante's Avatar
Re: Center caps
i was told theyre s-10 caps square body style
1967custom
michael bustamante is offline   Reply With Quote
Old 02-06-2024, 08:35 PM   #13
SCOTI
SCOTI's Avatar
Re: Center caps
Nope.
S10's & Sonoma's had their own specific caps. The ones posted initially were full-size B-body Impala/Caprice caps.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-06-2024, 10:46 PM   #14
CarlsLQ9SS
CarlsLQ9SS's Avatar
Re: Center caps
I tried these on a rough old truck wheel. This wheel is a Chevy 5 on 5 and they fit perfect, thanks everyone for the replies.
Carl
