02-23-2024, 11:25 PM | #1 |
Does the heater hose rub on the ac hard line on all of your trucks ?
So I am test fitting all my engine bay parts and I have tried multiple ways to stop this from rubbing. The larger upper heater hose points directly at the hard tube that curves behind the POA valve. I would think this would rub thru at some point. all the pieces I'm using are original to the truck so it's not aftermarket junk. I can't figure this one out.
02-24-2024, 12:06 AM | #2 |
Re: Does the heater hose rub on the ac hard line on all of your trucks ?
Yeah, I believe just a pinch. That and one of my AC hoses broke the no contact rule.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
02-24-2024, 12:17 AM | #3 |
Do these shots of my '69 help? I believe later trucks were a bit different. Probably a '71 change?
Jim |
02-24-2024, 12:22 AM | #4 |
Looking at my set up, I routed the top hose underneath that hardline nut. Seemed to be the best route. I believe both of my hoses contact that hardline. Can't say for sure right now.
Ah, yeah, mine is routed like first owners, above. I like where you installed that nylon strap Jim, I may have to do that.
02-24-2024, 06:26 PM | #5 |
Looks like mine('70) is mounted lower, on the vertical surface of the fender.
1970 C10 Custom longbed 350/350 |
02-24-2024, 11:07 PM | #6 |
Thanks for the pictures guys. Looks like the best way I could route the larger hose is to go in the loop of the ac hard line like firstowner69's truck. Nice engine bay. Looks sharp!
