Old 02-24-2024, 09:27 PM   #1
SilverGT3RS
67 C10 new Rear end question
Setting up a new 4.10 rear end in my 67 c10 12 bolt. Eaton TruTrak and new Motive gears.
Everything is going together as expected, and right now, my bearing preload is running around 22 inch pounds with nothing but WD40 lightly sprayed on the bearings. I am running a solid Raytec spacer with around a .022 spacer installed.
A big problem for me is I’ve seen pinion bearing preload numbers all over the board. Numerous drivetrain places via google search are showing 13-15 inch pounds. A few Chevy manuals are showing 15-18 inch pounds. Even more confusing, Strange and a few other aftermarket gear manufacturers call for 20-25 inch pounds. Not sure why there’s such a wide gap between numbers.
Can I get some opinions on this?
SilverGT3RS is offline   Reply With Quote
Old 02-25-2024, 05:13 AM   #2
pjmoreland
pjmoreland's Avatar
Re: 67 C10 new Rear end question
The higher numbers are for new bearings, and the lower are for used. The attached image is from the factory service manual.
20-30 in-lbs new
5-15 in-lbs used
pjmoreland is offline   Reply With Quote
Old 02-25-2024, 07:53 AM   #3
SilverGT3RS
20-30 in-lbs new
5-15 in-lbs used
Fantastic! I’m right around 22-23 inch pounds some I’m in good shape.
Thank you.
Old 02-25-2024, 11:31 AM   #4
jessemthompson
I installed a new set of Yukon gears last summer and it called for 13-15 inch lbs. I have it set at 15 and everything is working great.
jessemthompson is offline   Reply With Quote
Old 02-25-2024, 02:18 PM   #5
SilverGT3RS
Yes Yukon calls for 13-15 inch pounds. Which is way less than the Chevy spec quoted above.
However I did refer back to the Motive assembly sheet and it says to use FACTORY specs. So, I’m sticking with the 20-30 inch pounds as referenced.
