Alternator decoding
I’m thinking this is the original alternative for my 1968 part number 1100794 = 37a date code 7L8 I’m thinking that stands for 1967 December 8th am I off base ? I’m putting new bearings in it regardless it was charging but howling. I took it off the 68 stepside
Roadtrip!
![]() Join Date: Feb 2003
Re: Alternator decoding
Yes, it appears correct for your truck. 1968 307, 327 or 396 37amp.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
250 too?
![]() Join Date: Oct 2005
Test your diodes while you have it apart. A bad diode will cause a noise similar to a brg.
The alt will still charge with an open diode but will have much lower output. George |
Front bearing was toast was actually hard to turn the shaft . Rear wasn’t to bad but I replaced it to . Spins nicely now
I have a noisy one also. Can you elaborate a bit on the complexity of swapping out the bearings. Mine charges great but it is in need of new bearings for sure…thanks !
71 C-20 07 Magnum RT AWD |
Roadtrip!
Dec 8 of 67 is correct. My book only covers V-8, but may have been used on the 6 cyl also.
Very easy front is held in with cover with three screws just falls out . The rear needs to be pressed out and in but it’s really a simple job you will need a piece of thin wire to hold the brush’s in I use a small finish nail you can see it in this picture
Nice work.
George |
