Old 03-07-2024, 01:57 PM   #1
pjmoreland
pjmoreland's Avatar
Gauge Cluster with 8000 RPM Tach & Vacuum Gauge
This is a very clean factory gauge cluster that was rebuilt and modified to add an 8k tachometer and a factory vacuum gauge.
This build addresses the following issues present in the reproduction 8k tach kits sold by the truck parts vendors. The reproduction lenses have the green background paint applied to the wrong side of the lens which causes the backlighting to be poor at night. The tach numbers on the reproduction lenses are poorly spaced and do not line up with the tach markings. There is also an odd-looking set of smaller numbers in toward the center of the gauge. The font used for the reproduction lenses is different than the factory font. The 8k tach kits position the tach too high so that it does not line up well with the hole in the tin and numbers.
This build uses all OE parts, with the exception of the 8k tach itself and a new circuit. An OE lens is used and has custom tach & vac decals applied that achieve an OE look.
Here are the details on this cluster:
Tach - Brand new reproduction, Counterpart brand, 8k
Vacuum - Nice OE gauge that has been cleaned, lubricated and bench tested. It functions well and reads accurately. There is typical minor discoloration of the white lines and text on the gauge face.
Fuel, Oil, Temp & Battery Gauges - These are nice OE gauges that have been bench-tested. They all function correctly. Needles have been repainted.
Speedometer - This is a nice clean OE unit. I tested it by spinning it with a servo motor at precisely 1001 RPM, and it read 59mph (60mph would be perfect). I lubricated it and reset the odometer back to zero. Needle has been repainted.
Front Tin - OE - I added factory-style formed openings for the tach and vacuum gauges. Repainted black face of tin with 2k epoxy paint.
Back Tin - OE - I added the tach hole using a template made from another tach tin. I positioned this opening slightly lower than the stock 5k tach location to optimize the alignment of the tach with the lens numbers. The paint is factory, and is one of the nicest original tins I've seen.
Lens - OE - I polished off the dummy tach and vacuum markings and applied a die-cut decal for the 8k tach and VACUUM. The lens is nice, but has typical swirl marks on the front from being cleaned over the years.
Bezel - OE 67-68 style in excellent condition with no cracks. The argent silver paint is factory and shows some fading and small scrapes. This is one of the nicest factory original bezels I've seen. I have two other bezels that I can offer for the same price, if desired. One is a nice original 69-72 bezel that has been painted black. The other is a reproduction 69-72 style. Just let me know, and I can swap them out.
Printed Circuit - Brand new reproduction
Bulbs - Tested good
$500 + shipping (8k tachometers and vacuum gauges are expensive)
Money order preferred, PayPal accepted (you pay fees)
pjmoreland is offline   Reply With Quote
Old 03-07-2024, 01:59 PM   #2
pjmoreland
pjmoreland's Avatar
Re: Gauge Cluster with 8000 RPM Tach & Vacuum Gauge
More photos
Old 03-07-2024, 02:00 PM   #3
pjmoreland
pjmoreland's Avatar
Optional bezels
Old 03-07-2024, 02:01 PM   #4
pjmoreland
pjmoreland's Avatar
Indicator light testing
Old 03-07-2024, 02:02 PM   #5
pjmoreland
pjmoreland's Avatar
Fuel and temperature gauge testing
Old 03-07-2024, 02:04 PM   #6
pjmoreland
pjmoreland's Avatar
Battery gauge and speedometer testing
Old 03-07-2024, 02:05 PM   #7
pjmoreland
pjmoreland's Avatar
Oil pressure and vacuum gauge testing
Old 03-09-2024, 12:49 AM   #8
Orefactory4x4 swb
I’ll take it
Orefactory4x4 swb is offline   Reply With Quote
Old 03-11-2024, 04:43 PM   #9
pjmoreland
pjmoreland's Avatar
Sounds good. Thanks
Old 03-11-2024, 04:46 PM   #10
pjmoreland
pjmoreland's Avatar
I will be listing the following 8k tach cluster for sale after I finish building and testing it (no vac gauge).
Old 03-17-2024, 10:46 PM   #11
pjmoreland
pjmoreland's Avatar
Payment received from Orefactory4x4 swb. Thank you. Will ship tomorrow. Here's how it looks with the reproduction bezel installed.
Old 03-18-2024, 10:34 AM   #12
Orefactory4x4 swb
Appreciate it… it looks great..
Old 03-20-2024, 10:28 PM   #13
Orefactory4x4 swb
Received today, just like advertised… looks fantastic great job..
Old 03-20-2024, 10:29 PM   #14
pjmoreland
pjmoreland's Avatar
I'm glad it made it there safely, and thank you for the feedback.
Old 04-05-2024, 06:14 AM   #15
4Harpers
I'll take the other one.
4Harpers is offline   Reply With Quote
Old 04-05-2024, 12:17 PM   #16
pjmoreland
pjmoreland's Avatar
That one is already sold, but I am making a 5k tach/vac cluster right now. Let me know if you're interested in that one.
Old 04-08-2024, 01:02 PM   #17
54blackhornet
54blackhornet's Avatar
PJ that’s some beautiful work…
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 04-08-2024, 01:06 PM   #18
pjmoreland
pjmoreland's Avatar
Thank you
Old 04-14-2024, 10:59 PM   #19
External
External's Avatar
Very nice work. I'm going to save up some money now.
I know you will have people lining up!
'72 Chevy Custom Deluxe Highlander. Med Olive/White 350/200 ps,pb and Air Conditioning!
External is offline   Reply With Quote
Old 04-14-2024, 11:02 PM   #20
pjmoreland
pjmoreland's Avatar
Thank you. I have this one listed for sale right now.
https://67-72chevytrucks.com/vboard/...d.php?t=851981
