03-09-2024, 10:57 AM | #1 |
Help me eliminate strong fuel vapors in garage
Some of you may have followed my earlier post about buying a new 1969 c10 250 last week.
Prior to my ownership, the truck sat for over a decade. I have the truck parked in my garage now and there’s one problem. The gas vapors are overwhelming and begin to creep into the first room of the house adjacent to the garage. So the first thing I’m planning on doing is addressing that. Here is what I see: a.) Gas cap rubber gasket is cracked. I have a new gas cap on the way. b.) The short piece of soft fuel line between the tank hardline and the fuel pump is very soft/worn. I picked up a piece of 5/16” soft line with clamps and will replace that c.) I see that there is a small fuel leak at the carb. I’ve ordered a carb rebuild kit to try to address that (pic below). Other than that, I don’t see any obvious leak. Additionally, I don’t detect any fuel vapors inside the cabin (source of smell is external). Are there any other areas I should be looking at that are common sources of fuel vapors that I should also check on? I’ll start with a/b/c above and report back how things are looking. Thank you! |
03-09-2024, 11:10 AM | #2 |
Re: Help me eliminate strong fuel vapors in garage
1969 trucks vented the carb and fuel tank to atmosphere, so there will be a slight fuel odor even if everything is new and tight. 1970 10 series trucks with RPO NA9 evaporative emission control and 1971-72 10 series used a sealed fuel system where fuel vapors were stored in a charcoal cannister, then eventually burned when the engine was running.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
03-09-2024, 11:17 AM | #3 |
Thank you for pointing that out.
Although some vapors are expected given the ‘69 design, it seems it’s way excessive. With a visible leak, I should probably address that before reaching any conclusions. |
03-09-2024, 11:18 AM | #4 | |
03-09-2024, 11:56 AM | #5 |
There is another short piece of rubber fuel line between the frame and the hard line under the rear of the cab. I recommend replace that since you're replacing the one at the fuel pump. Don't just go out there and squeeze it unless you have a new one ready, or a bucket to put under it and wrench ready to loosen the hard line at the sender, or it might crumble in your hands and accidentally siphon all the gas from the tank onto the ground.
And there is a rubber seal between the fuel sender and the tank, which you can get to by moving the seat forward. The fuel sender is near the top of the tank behind the seat. After removing the fuel line and electric wire from the sender, turn the lock ring counter clockwise. There is a special tool sold to turn that ring, but I simply used some large pliers with jaws open to press against the tangs to loosen and tighten that. howzzzit mentioned the fuel pump itself, and there is rubber inside it. If the rubber in it is old it could be it was not the type of rubber that tolerates ethanol. Newer formulations of rubber must be used with gasahol. I bought a Delphi cheap fuel pump at Autozone and it has lasted about 5 years now, and I use gasohol, so I think it has the right rubber in it. There are problems with new fuel pumps that I have seen posts about on the forum about them failing fast, and some producing too much pressure and causing carbuetors to flood. So approach fuel pump problems with a little caution and if you install one you don't necessarily get to think you're done with that. I have a 69 that I park in the garage and it doesn't have strong fuel smell so I think you are heading toward a solution. Be careful, and keep a fire extinguisher handy, and a buddy present and standing by if possible, while working on fuel stuff. And perhaps work on it outside. |
03-09-2024, 09:53 PM | #6 | |
Hmmm, if I break that soft line connection, I can’t see losing more fuel than was in the lines to start right? I mean the fuel in the tank needs to make its way up through the sending unit so I struggle to see any siphoning effect being possible? |
03-09-2024, 10:13 PM | #7 | |
03-09-2024, 11:02 PM | #8 |
Yes it'll surprise you and start siphoning right away and rather fast unless you open the hard line at a point higher than the level of fuel in your tank.
03-09-2024, 11:20 PM | #9 |
I'd definitely change that stuff outside, especially if you have a gas hot water heater or clothes dryer in that garage. Be careful.
03-10-2024, 02:20 PM | #10 |
Thanks all, I’ll be sure to brake the hardline connect at the tank before replacing the soft lines.
One thing I do notice is that the rubber pass-thru grommets on the valve cover are badly worn (these are the inlets of the air tubes off the carb). Can those lead to a strong gas smell as well? |
03-12-2024, 12:10 PM | #11 | |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 03-12-2024 at 12:19 PM. |
03-17-2024, 05:32 PM | #12 |
I had a chance to get under the truck and did a bit of investigation.
- there’s no fuel smell inside the cabin - the short stretch of soft line between the tank and the hardline under the cabin looks to be in good shape, no leak there. - hardline under the truck looks fine. - now the soft line leading up to the fuel pump is in terrible shape… very old and soft. There’s evidence that there was a leak under the fuel pump at least at some point. I’ll replace that soft line as soon as possible and I’m thinking maybe I should replace the fuel pump too for good measure. You can see there was a leak under the fuel pump (could be that soft line or it may be the pump weeping)? I ran my hand under the fuel pump, brought it up to my face, and it was strong scent of raw fuel. How involved is a fuel pump swap in one of these 250s? I see the are pretty cheap on RockAuto. |
03-17-2024, 06:26 PM | #13 |
Who Changed This?
That like appears to be dry as a bone. It's probably leaking if it's wet underneath. But you could inspect the pump underside with a mirror, for verification. Pump is a piece of cake. Have you downloaded the manuals yet?
03-17-2024, 06:42 PM | #14 |
That like?
You can see the rust spot where the fuel was leaking (at least at some point) Will DL the manual Any tricks to the mechanical armature positin being in the right position ? |
03-17-2024, 07:29 PM | #15 |
Now is the time to fix the whole fuel system and you don't want to do it twice or your garage will smell like gas
There is a bolt at the front of the engine that will keep the fuel pump shaft from falling out while you r working on it
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
03-17-2024, 07:36 PM | #16 |
I thought that was only for v8?
03-17-2024, 08:40 PM | #17 | |
Who Changed This?
Also, there is a low section of the cam that, if you get to it, makes pump installation easier against the lower spring pressure.
03-18-2024, 12:58 AM | #18 | |
03-18-2024, 02:29 AM | #19 |
Will do. Just ordered a replacement Delphi fuel pump on RockAuto for $11. Did I mention I love the parts pricing on this truck (at least compared to my Lexus and my Wife’s Land Rover)
1969 C10 Shortbed Wanted (pm me): - Pair of 275/60/15 tires |
03-18-2024, 02:41 AM | #20 |
03-18-2024, 03:57 AM | #21 |
Location: Herculaneum MO (20 minutes south of St. Louis
All I can say is good luck. When I put the 292 in mine in place of the 250 I figured I'd replace the pump just because. That was a mistake. The new pump would flood the carburetor out. When I checked the pressure it was running 7 1/2 at idle and more like 9 at higher RPM. Max fuel pressure on these 6s is either 3 or 3 1/2 I forget which. I returned that pump & used the old one off my 250.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
03-18-2024, 10:01 AM | #22 |
Sorry I'll play my old grey card
03-18-2024, 11:26 PM | #23 | |
