03-13-2024, 08:10 PM | #1 |
Running exhaust
Is there any reason not to run my exhaust the way I have it? Ground clearance is fine and not hitting anything on the frame. Nothing welded or hung yet just mocking it up. Was thinking about going down, under axle, turning out and then back on each side of the tank going straight back below bumper. 2 1/2" 304 ss from headers all the way back.
Thanks Rick |
03-13-2024, 08:14 PM | #2 |
Re: Running exhaust
The U bends behind the mufflers are just on there for now not running it that way.
03-13-2024, 09:36 PM | #3 |
Born Psycho
Re: Running exhaust
i work in a muffler shop- almost 40 years- and personally i think it's too low. i would route it up through the trailing arm crossmember to get the mufflers higher. cut a round hole in the crossmember and weld in a 4 inch piece of pipe to run the pipes through welding in the 4 inch pipe helps strengthen the crossmember. just my opinion.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
03-13-2024, 10:25 PM | #4 |
Re: Running exhaust
I don't think I would go under the axle.
On mine it goes over the axle turns and wraps around both sides of the gas tank and turns down and out behind the back wheel. |
03-13-2024, 10:53 PM | #5 |
Re: Running exhaust
cj847 do you have any pictures?
03-14-2024, 12:15 AM | #6 | |
Re: Running exhaust
I agree that it seems pretty low, unless the streets where you live are very, very flat.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
03-14-2024, 06:14 PM | #7 |
Re: Running exhaust
03-14-2024, 07:09 PM | #8 |
Re: Running exhaust
Just a note on the driveshaft....it looks to be to short. Quite a bit of yoke extending out of trans.
03-14-2024, 11:19 PM | #9 |
Re: Running exhaust
Its a long yoke. there is 3" in the trans. Only 1 1/4" sticking out. It was too long and was bottomed out shortened it the minimum and now 1/4" shorter than I would have liked. pretty mild build 383 400 HP but no hook J's for me.
As for exhaust I am offsetting the mufflers up. Tail pipes will go over axle then down about 45deg and around fuel tank like cj847 describes. I will post pictures when I get it moved up. Two more 180 degree bends ordered to get them over and out. |
03-15-2024, 09:49 AM | #10 |
Re: Running exhaust
In my opinion, I agree with the other member in that it is hanging way too low.
My old exhaust system was run under the crossmembers, and when you step back, you could see the entire exhaust system...looked like some farm kid welded it on a Friday night just to cruise around. New system is tucked up into the middle of the frame rails. Can’t see the header collectors, or anything else, until it pops out in front of the rear wheels. It’s all 3” with 4” exits.
"If it ain't broken, fix it 'till it is!" |
03-16-2024, 06:55 AM | #11 |
Re: Running exhaust
Here’s a visual on the crossmember pass through. These are heavily modified Dead End Garage, from Pro Performance. Added a top section to mount the Holohan Hot Rods hangers. As said previously, this will keep the exhaust tucked up in the frame rails.
03-16-2024, 08:57 AM | #12 |
Re: Running exhaust
Here’s another shot of the mocked up routing you could consider
03-16-2024, 08:11 PM | #13 |
Re: Running exhaust
Halfbrit I like your set-up. I did move mine to the outside of the crossmember from there it is ran like yours except under the crossmember. It is highest towards the outside than where i had it before. My truck only has a 3 inch drop and stock size tires. So now at the lowest point I have 11.5 inches of ground clearance. When I get to the shop I will get some pictures.
03-20-2024, 09:14 AM | #14 |
Re: Running exhaust
Finally got some bad pics. Hope it helps a little. What I like- tucked up as much as possible, can't see the tailpipes when walking around the truck. Truck is 2.5/4" lowered with 28" dia tires.
In front, the tailpipes are as tight as possible to the frame (ie pipe dia + .5-1") below frame rail is lowest point. In back, the pipe is aimed down behind the rear tire and is cut off parallel to the ground. They are barely lower than the sheet metal of the truck. I couldn't get a good pic of the over axle. Here is the passenger side. My muffler is laid flat, but I don't think that matters. Just up and over, then a tight turn toward the outside. I like that it is subtle and effective. |
03-20-2024, 06:24 PM | #15 |
Re: Running exhaust
CJ847 Thanks for the pictures. Thats close to what I want but going straight out of the back. I raised it up as high as it would go. Now my lowest point is right at 12". I did get one side offset kinda mocked up but did not get a picture but here is a couple I got the other day after raising everything.
Rick |
03-20-2024, 09:12 PM | #16 |
Re: Running exhaust
I ran back over to the shop and got this picture. Everything still needs to be squared up and hung but I think this is what I'm going with. 12" of ground clearance should be fine.
