Old 03-15-2024, 06:40 PM   #1
howzzzit
howzzzit's Avatar
Shock absorber suggestions
I have a C10 short bed with coil springs. Just getting it back on the road after years. I know the current shocks are Monroe with very few miles on them. I don't like them at all. I can run over a trail of ants and feel it in my teeth. What are some suggestions for a smoother ride using a basic shock? Ideas and successes appreciated.
howzzzit is offline   Reply With Quote
Old 03-15-2024, 06:41 PM   #2
Shifty One
Shifty One's Avatar
Re: Shock absorber suggestions
Bilstein.
1987 V20 farm-hand rescue
1998 C2500 lot-rot rescue
Old 03-16-2024, 05:33 AM   #3
cj847
cj847's Avatar
I had the same issue. Brand new blue shocks that were worthless. The best shock I have used on these trucks is KYB Gas a just. Makes a huge difference.
KG 5409 front.
KG 5416 rear.
cj847 is offline   Reply With Quote
Old 03-16-2024, 08:40 AM   #4
novaX522
KG 5409 front.
KG 5416 rear.
X2, I’ve been really impressed with my KYBs
novaX522 is offline   Reply With Quote
Old 03-16-2024, 09:48 AM   #5
bowtie72
bowtie72's Avatar
I was thinking of making the same thread. The last set of KYB shocks I bought were made in china and didn’t last a year. They for a different vehicle. I’m looking for a little higher end shock. Bilstein? QA1? Both of my trucks are lowered. Just looking for a good gas charged shock that will last.
1968 SWB "Little White Truck"
1972 LWB LS 4l80 "Plain Jane!!"
bowtie72 is offline   Reply With Quote
Old 03-16-2024, 09:54 AM   #6
Mike C
Mike C's Avatar
Bilsteins are great shocks. Probably what I will go to on my 69 short step when I replace the current shocks.
My truck is 4 1/2” drop in front with spindles and 2” springs and I am running a stock length KYB GR2, not Gas-A-Just. My truck is a leaf spring rear which has been flipped and upper shock mount rotated to be more vertical. I also run stock length FRONT shocks on the rear, the same KYB GR2 and I have been very happy with them.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-16-2024, 10:23 AM   #7
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Shock absorber suggestions
I use Bilstein on all my cars, and 2wd trucks. I have used genuine Ranchos on the Blazer and the two 4wd daily drivers with good results.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress...
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels
1970cstblazer is online now   Reply With Quote
Old 03-16-2024, 11:22 AM   #8
weq92f
weq92f's Avatar
X3 -- Tried the normal non Gas-A-Just first...not so much. Swapped to Gas-A-Just for the win.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 03-16-2024, 11:07 PM   #9
cericd
cericd's Avatar
Is your truck lowered or stock height?
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 03-16-2024, 11:58 PM   #10
Rick Bollinger
X4 KYB gas a just
Rick Bollinger is offline   Reply With Quote
Old 03-17-2024, 01:13 AM   #11
howzzzit
howzzzit's Avatar
All stock
Old 03-17-2024, 01:35 AM   #12
Rick Bollinger
Mine is 2 1/2 spindles front. Back 2" springs 1" blocks for 3 inches
Old 03-17-2024, 07:22 AM   #13
Luke87gt
How much max drop will those KYB support? They are pretty cheap on RockAuto at $3x a piece
1969 C10 Shortbed
Wanted (pm me):
- Pair of 275/60/15 tires
Luke87gt is offline   Reply With Quote
Old 03-18-2024, 01:21 AM   #14
howzzzit
howzzzit's Avatar
Gonna try the KYB. Thanks everyone. I'll post when I get them on.
Old 03-18-2024, 10:40 AM   #15
Shifty One
Shifty One's Avatar
Unhappy Re: Shock absorber suggestions
They are not the shock that they used to be. A lot of the big "name brands" that we grew to trust over the decades, have fallen to overseas production, and quality has suffered as a result. (try and find an American-made brake rotor nowadays).
Old 03-24-2024, 07:46 PM   #16
howzzzit
howzzzit's Avatar
Well installed the KYB shocks, but haven't driven yet. Too rainy lately. When I removed the Monroe shocks all four were shot. No charge at all. Now these shocks were very low mileage and the truck had been sitting for several years, but should they fail from sitting? The only issue I had installing the KYB was the bottom front mount on the truck. The shock bushing was wider than the opening so had to do some grinding to make it fit. Second set of Monroes on this truck, but never again.
