03-19-2024, 12:29 PM | #1 |
Active Member
Engine code or date code?
Question, my 1969 396 engine has the following stamp on the passenger side: 10 21 YS , is this a date code ?
Thanks ! |
03-19-2024, 12:53 PM | #2 |
Re: Engine code or date code?
the casting date is on the back of the block near the bellhousing flange on the passenger side and its cast into the block not stamped.
I think what your posting is the front pad code, YS comes up as a 69 Truck motor.
The Twins: 1968 C10 SWB - Blue 327/5 Speed 1968 Camaro SS/RS - Blue 327/4speed C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278 The "Others" 1933 Ford Pickup (Camaro in disguise) 2017 Camaro SS Life long Chevy guy |
03-19-2024, 01:06 PM | #3 |
Active Member
Thanks !
03-19-2024, 01:09 PM | #4 |
10 21 is the engine assembly date- October 21
YS suffix code is for a 1969 396 truck engine, 310hp, 4bbl carb, manual transmission There should be a letter at the very beginning of the stamped code that will tell you the engine factory. F- Flint, MI (1955-1966) V- Flint, Mi (1967 and newer) T- Tonowanda, NY K- St. Catherine, Ontario S-Saginaw, Mi M- Mexico The date cast into the block is the date when the block was cast and which shift it was cast on.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
03-20-2024, 04:43 AM | #5 |
Active Member
thanks !
03-20-2024, 06:58 PM | #6 | |
I have 292 blocks from '67 and '68 that have F codes in the stamped dress numbers.
03-20-2024, 07:36 PM | #7 | |
03-20-2024, 08:19 PM | #8 |
Then theres this chart from Inliners International, its not clear if the six cylinders remained F and the V8's changed to V. The Lime Book only covers V8's.
https://www.inliners.org/ubbthreads/...t&Number=66011
03-21-2024, 01:00 AM | #9 | |
03-21-2024, 08:17 AM | #10 |
The Lime book is good, but some info is not 100 percent correct. For example, the engine code on my Blazer's 1970 350 4 speed is:
V0223TBC V Flint 0223 February 23, 1970 TBC is listed in that book as a 1970 350/255BHP 4 barrel carb truck engine with a 3 speed manual trans.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
03-21-2024, 12:40 PM | #11 | |
Looks like https://www.nastyz28.com/gm-chevy-co...s-suffix-6.php is incorrect as well then even though it shows it as MT, 3 spd. If there are better sources for this information feel free to post it up. The GM book simply shows Manual transmission, does not specify 3 speed or 4 speed. http://www.gmpartswiki.com/getpage?pageid=21050 The GM P&A catalog does not specify the change from F to V or addition of V to the engine plant identifier. The things I've seen that is common among these sources (Lime Book and nastyZ28) is F is Flint (Motor) and V is Flint (Engine). Also, the Lime Book is only V-8's, no mention of 6 cylinders and I guess I didn't say that applied to 6's either. Its possible the 6's kept the F prefix, we all know there are many other nuances with these trucks that don't seem to follow logic or are well documented.
03-21-2024, 02:07 PM | #12 |
Do you think the folks with 2024 pickups will be sleuthing like this in 50 years .
71 C-20 07 Magnum RT AWD |
