03-19-2024, 02:17 PM | #1 |
Front spindle assembly question
I am changing the wheel bearing and found this rubber gasket on the backing plate behind the wheel seal. Is this normal?
1967 C10 Step side 1970 AMX 390 1977 Datsun 280Z highly modified with '95 LT1 power |
03-19-2024, 07:53 PM | #2 |
Who Changed This?
Re: Front spindle assembly question
Yes.
03-19-2024, 08:35 PM | #3 |
Thanks. Weird that I don't remember those things when I put the drop spindles on years ago.
03-19-2024, 08:59 PM | #4 |
One thing I did notice when I pulled the seal the grease on the seal and the inner bearing was black. As I remember when I replaced the front rotors they came with the inner bearings and seal already installed. The only grease I have ever used is high temp red, which is what was on the outer bearing and the spindle.
