Old 03-21-2024, 03:22 PM   #1
pound41
will a lift kit from a 1975 K10 work on a 1971 K5
Hello:
I have a 1971 blazer. A friend has a rough country lift kit for his 1975 K10 that he has never installed. He says it will fit my 71 blazer. I have looked at several companies that make their own springs. Their springs are listed by weight. According what I think I saw there. they will fit. Thanks for your time
pound41 is offline   Reply With Quote
Old 03-21-2024, 07:29 PM   #2
Blazerowner
Blazerowner's Avatar
Re: will a lift kit from a 1975 K10 work on a 1971 K5
I believe the springs are a different length. If I remember right ORD sells brackets to use the longer springs from 73 up.
Kirk
72 Blazer CST 4wd highlander
66 Nova
Blazerowner is offline   Reply With Quote
Old 03-21-2024, 08:24 PM   #3
pound41
OK thanks I have learned the newer years fronts are longer but the rears are the same 52in
Old 03-21-2024, 10:01 PM   #4
jerry moss
Born Psycho
jerry moss's Avatar
Question Re: will a lift kit from a 1975 K10 work on a 1971 K5
if my "old" memory serves me correctly, even though the rear springs are the same length, the amount of lift will be different between square body and our 69-72s. i believe it's a 2 inch difference but check with the manufacturer first, don't take my word for it.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 03-23-2024, 11:39 AM   #5
pound41
Jerry Moss
you are correct. A squarebody 2in lift kit says rear springs will lift it 2 inches in the rear. Yet 2.5 in kit for our trucks uses 4inch in the rear to get close to level.
Spring Strength ? Would probably be the answer
Old 03-24-2024, 03:46 AM   #6
Richard
Always remember the Blazers of any year squatting in the rear with a lift. Think the truck springs are included in the off the shelf mainstream lifts, but Blazers are heavier in the rear. Old quick fix was to use an add a leaf to get the rear up. Firm ride was the consequences of that. Personally, I like the look of back squatting a bit on a 4x4. To each their own.
Richard
