03-24-2024, 11:52 PM | #1 |
What is the hub diameter on a 1969 6-lug 2wd?
Is anyone able to help confirm this? Thanks
1969 C10 Shortbed Wanted (pm me): - Pair of 275/60/15 tires |
03-25-2024, 12:09 PM | #2 |
Re: What is the hub diameter on a 1969 6-lug 2wd?
Are you looking for the measurement on the rear axle registers (diameter of the step that the rim fits over)?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
03-25-2024, 11:40 PM | #3 |
Diameter of the hub that the rim rides on
03-26-2024, 08:31 AM | #4 |
If it’s the same for a ‘70 I can measure mine after work today.
03-26-2024, 08:21 PM | #5 |
Thank you. Is it 6lug?
03-26-2024, 08:34 PM | #6 |
Active Member
11 inch
Old dogs and children and watermelon wine |
03-27-2024, 01:24 AM | #7 |
Oh wow
Let me try asking this another way What is the oem wheel bore diameter of a ‘69 6lug c10 wheel?
03-27-2024, 06:45 AM | #8 |
I will measure mine after work today and post the measurement.
03-27-2024, 07:17 AM | #9 |
My wheels have a center bore of a hair over 108mm or a hair over 4.25 inches. I also founds from and saved some notes from some tire place that it is 108.1mm since all the tire folks seem to use the metric stuff no inches for measurements
03-28-2024, 05:55 PM | #10 |
The spacers I used on the '70 show the i.d. as 3.08".
15" steel wheels
1970 C10 Custom longbed 350/350 |
03-29-2024, 12:54 PM | #11 |
03-29-2024, 05:21 PM | #12 |
I must be looking at something else then :shrug:
03-29-2024, 08:14 PM | #13 |
I've been watching this thread and now feel it's time to contribute conflicting information and generally add confusion, which is sometimes my specialty! We need some chaos!
I converted by 69 C10 to 71-72 5 lug. I went out to the garage with a ruler to measure the center hole on my old 6-lug wheels still sitting there and it is 3.5 inches. The 6-lug wheels fit into the hubs on the truck very well, hub centric mount. Luke87gt does this match what you actually have on your 69 C10 if you remove a wheel or hubcap and measure? New 5-lug setup has 3 inch center hole. I thought long and hard on my truck whether to stick with 6 lug or do 5 lug, and I've got to say I highly recommend 5 lug if disc brakes or new wheels are in the future. With 5 lug and C10 you can use all stock parts from 71 or later, and the only conversion thing you would need is rear axel shafts, which were inexpensive. And wheels are less expensive and easier to find and easier to just know they are compatible with disc brakes. Converting to 5 lug will also get you to change your rear bearing and seals, change the differential oil, and fix the broken pinion shaft lock bolt. Oh boy, more stuff to fix, even better. I don't know what's up with the other measurements here in the thread, because I expect myself to be right, but maybe I'm wrong, who knows. I've been watching too much Visegrip Garage, I don't know. Last edited by dmjlambert; 03-29-2024 at 08:27 PM. |
