Old 03-28-2024, 02:58 AM   #1
Richard
Floor heat diffuser
Attached a couple of pictures of my floor heat outlet. Do the square/rectangular openings require a door that can close or open? Took this out a long time ago and am converting to factory type A/C-heat boxes. There are some doors that can be opened in the heater core enclosure. Wondering if those should be in lower heat outlet. Maybe someone cut the holes before I bought the truck? Any input would be appreciated.
Richard
Richard
Old 03-28-2024, 11:58 AM   #2
purple gas
Re: Floor heat diffuser
That looks like the whole Kit & Kabootle to me.
They weren't very fancy back in the day.
I got a bench seat baby, you don't have to sit over there.
purple gas is offline   Reply With Quote
Old 03-29-2024, 02:01 AM   #3
Richard
Thank you for taking the effort to reply. If it looks like the factory stock piece I will run it as is. Need to get it installed on the truck now.
Richard
Old 03-29-2024, 09:31 AM   #4
Steeveedee
Who Changed This?
Steeveedee's Avatar
I'll go take a look at mine when the sun comes up, but that looks right, from here.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 03-29-2024, 11:31 AM   #5
Steeveedee
Who Changed This?
Steeveedee's Avatar
Yup, looks like mine- w/ factory AC.
~Steven
Simi Valley, CA
Old 03-29-2024, 12:55 PM   #6
Casper42
Casper42's Avatar
that looks spot on correct. the nearest open/closing door is the part to the right (passenger side) that connects to the part in your pic, which controls the flow from dash to floor to vents-if A/C model
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass
New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus!
Casper42 is offline   Reply With Quote
Old 03-30-2024, 02:34 AM   #7
Richard
Thanks to Steven and Casper for further confirming my part is unmolested. This part is only used from my heat only system. All the other A/C parts I have were obtained from other trucks years back.
@Steeveedee would like to take another peek at your truck. Forgot you have factory A/C. Will help me a lot.
@Casper42 There are some small square openings on the bottom of the heater core enclosure that can manually be opened up. That is what I was referring to.
Richard
Old 03-30-2024, 12:09 PM   #8
Steeveedee
Who Changed This?
Steeveedee's Avatar
The truck could use some exercise. I'll give you a call.
~Steven
Simi Valley, CA
Old 03-31-2024, 02:35 AM   #9
Richard
Thank you for coming by today. It was good to see you again and I enjoyed the conversation. The opportunity to see your factory A/C was a big help for me as the books do not always make it clear for me. Maybe we can get together when the weather is a bit warmer
Richard
Old 03-31-2024, 11:39 AM   #10
Steeveedee
Who Changed This?
Steeveedee's Avatar
You are welcome. It was fun watching hail come down, too!
~Steven
Simi Valley, CA
