Old 03-31-2024, 05:02 PM   #1
dhigdon@southerntank
700 r4 and Sniper 2
Has anyone installed a Sniper 2 with a 700r4 transmission? Are there any brackets available for attaching the tv cable to the sniper?
dhigdon@southerntank is offline   Reply With Quote
Old 03-31-2024, 10:34 PM   #2
Rick Bollinger
Re: 700 r4 and Sniper 2
Bow Tie Overdrive is the way to go. They make a great system. Not the cheapest but a quality system. It comes with a throttle arm linkage with the correct geometry for the 700R4, bracket under the sniper for the cable, cable and a special spring for the throttle valve. When you get it all hooked up you call them and go over the pressures and they tell you if it's good to go or not. I also used the B&M lockup kit to control lock-up at speed.
Rick Bollinger is offline   Reply With Quote
