04-03-2024, 05:17 PM | #1 |
Identifying a hole in my floor
Hi All, I was hoping someone on here could help me identify this hole in the floor of my 59. More importantly, can someone help me identify a plug for said hole?
04-03-2024, 11:08 PM | #2 |
Re: Identifying a hole in my floor
Original hydromatic truck?
04-04-2024, 01:08 AM | #3 |
I dont think so...Was the hydromatic just a GMC thing? The LMC catalog shows the same hole, but they also told me they dont sell a filler for it.
04-04-2024, 08:27 AM | #4 |
I think that’s the location of the stomp starter.
04-04-2024, 02:19 PM | #5 |
I am going to go with Foot Starter Hole.
04-04-2024, 04:30 PM | #6 |
Thanks for the feedback, that seems like most best answer.
04-04-2024, 05:08 PM | #7 |
1958:
04-05-2024, 01:41 AM | #8 |
Dang, that one got me last night. Yuppers, for sure the stomp pedal hole, this one covered with a piece of galvanized tin.
04-05-2024, 09:25 AM | #9 |
you could fab your own formed metal patch pretty easily that fits into the hole with a raised perimeter edge thatcould be glued to the floor with urethane sealer, like windshield caulking. thats if you cant find a rubber grommet. otherwise, find a rubber grommet that if slightly larger and simply expand the hole to fit the grommet. or fab a ptach that fits the hole and weld it in.
04-05-2024, 09:27 AM | #10 |
go to a truck tire repair shop ang grab a couple of patches and glue one on from each side if youre not worried about the look.
04-05-2024, 09:30 AM | #11 |
There have been many request for a "grommet" plug for that hole. With many threads with folks looking for one. over many years.
Don't believe they are to be found. So I would just plan on making a patch/plug/weld/Glue to meet your need. |
04-05-2024, 12:42 PM | #12 |
Its nice to hear I'm not the only one who has struggled to find out what it was AND want a plug for it. I found a patch option on amazon.... Im going to give it a try! Guess and Check and Repeat.
04-06-2024, 09:00 AM | #13 |
I thoughtof those plugs, they are used in front floor areas and trunk areas in sedans, but thought they were usually too small for that hole. worth a try though. easy enough to fab up one for your needs too. they are usually glued in.
04-08-2024, 09:20 PM | #14 |
The plug on Amazon looks like the right shape. There are also repros of OE plugs with tabs: https://www.chicagomusclecarparts.com/products/918731
Urethane is a great adhesive and it's good at filling gaps. Once you open the tube it begins to cure and it can only be stored for a short time before the entire tube is cured. I'd look for smaller tubes from one of the big box stores. Even better, they're available in different colors. |
04-09-2024, 10:54 AM | #15 |
The shape of the amazon plug was pretty good. I'll end up trimming it just a touch i think. Thanks for all the info and help. I entered the truck (as a long shot) in the small automotive section of our yearly MotoShow and they accepted it. So now im in a scurry to seal up a few of the long outstanding issues.
