Old 04-10-2024, 11:08 AM   #1
Chevys4life
Proportioning Valve Wire
Can anymore tell me where I can buy one of these short extension wires from. I'm adding power brakes to my drum brake truck and need this proportioning valve extension.
Chevys4life is offline   Reply With Quote
Old 04-10-2024, 04:12 PM   #2
Rust_never_sleeps
Rust_never_sleeps's Avatar
Re: Proportioning Valve Wire
the new combo valve should come with the wire
1970 C10 Custom longbed 350/350
Rust_never_sleeps is offline   Reply With Quote
Old 04-10-2024, 05:57 PM   #3
72SB
Its likely a different connector on the new PV for power so just splice that new pigtail into your wiring. Or if you just need same connector, just splice in a longer piece of wire. What I did.
72SB is offline   Reply With Quote
Old 04-10-2024, 06:13 PM   #4
57taskforce
All about them K’s
57taskforce's Avatar
lol the way you are holding the wire made me laugh. We take random pictures like that and send them to each other at work
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
57taskforce is online now   Reply With Quote
Old 04-10-2024, 08:49 PM   #5
dmjlambert
dmjlambert's Avatar
It seems some others are thinking you are getting a new proportioning valve. It may be because you called the drum brake distribution valve a proportioning valve. If you are not getting a proportioning valve and are simply moving the existing distribution block out from the firewall, you probably have some options. Re-route the wire if it is taking an inefficient route like through wire channel on the firewall and wire clip, and instead run it from the firewall connector in a more direct way to the distribution block, or splice in a piece of wire to lengthen it and route it any way that looks neat, or become a subscribing member of the forum and post a want-to-buy ad in the parts section and ask for somebody to send you that wire. I didn't know there was such an extension wire like that. There are people here on the forum who have their original wire harnesses stashed and offer parts and pieces to people who need them in response to want-to-buy ads, I have experience with that.
dmjlambert is offline   Reply With Quote
Old 04-10-2024, 09:24 PM   #6
Rust_never_sleeps
Sorry, I misread power brake conversion as disc+power.
I just spliced mine.
Old 04-10-2024, 09:49 PM   #7
67RS/SSx2
What does the wire do?
1972 C20 402/TH400/3.54 Highlander
1969 Camaro RS with SS trim, 1967 Camaro RS/SS (sold)
1983 GMC Sierra Classic 2500 crew cab (sold)
1972 Chevy C10 Cheyenne Super (sold)
1984 Chevy Silverado C20 crew cab (bought new by my uncle, in the family until I sold it)
67RS/SSx2 is offline   Reply With Quote
Old 04-10-2024, 09:50 PM   #8
Rust_never_sleeps
Lights the warning on the dash when there's a pressure loss in either front or back
Old 04-11-2024, 12:02 PM   #9
Chevys4life
lol!!!
Old 04-11-2024, 12:07 PM   #10
Chevys4life
You are correct and it is only a distribution value and not a proportioning value. I think I kept the old old wire harness that I took off the truck so i just extend it when the time come. Thanks for the correction and I will just modify the existing one. I know what your talking about removing it from clip on the fire wall.
