Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 04-11-2024, 10:54 AM   #1
truckster
truckster's Avatar
Is your Bronco on fire? Ford has the fix...
Rather than actually fixing leaking injectors, Ford dealers will install a tube to allow the fuel to drain to the ground. They'll also install software to cripple your engine if the ECU senses low fuel pressure:
https://www.carscoops.com/2024/04/fo...blem-persists/
Is the ghost of the Pinto hanging around Ford headquarters?
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is online now   Reply With Quote
Old 04-11-2024, 11:20 AM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Is your Bronco on fire? Ford has the fix...
The pony is taking lessons from Edsel?
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 04-11-2024, 05:37 PM   #3
weq92f
weq92f's Avatar
Throwing software at a hardware problem. Yes...it's been done before.
In 2009 or so, bmw knew they had a hardware issue with their turbos on the new twin turbo 3 series (335). Indeed the fix was a software fix that reduced the engine output in an attempt to mask, delay, prevent turbo waste gate failure. This was met with a very huge outcry from consumers of these vehicles. Eventually they ponied up and fixed the engines with actual hardware but it took some pushing to make them do it right.
Ferd is admitting there will be a fuel leak and they simply want software detection of leak to maybe shut off or put the engine in limp mode to provide safety...oh and a DRAIN PIPE? Jesus.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 04-11-2024, 08:36 PM   #4
yuccales
yuccales's Avatar
Originally Posted by weq92f View Post
....oh and a DRAIN PIPE?
Yeah no fooling! Ought to go over real well in my nanny state. Heck, pretty soon I wont be able to get a two stroke weed eater!
yuccales is offline   Reply With Quote
Old 04-11-2024, 08:51 PM   #5
Getter-Done
Getter-Done's Avatar
84 Chevy K-20
Old 04-11-2024, 08:53 PM   #6
72c20customcamper
72c20customcamper's Avatar
They pee fuel on the ground but we need EPA approved gas cans .
Dodge did something similar the 07 trucks and jeeps and other years when you shifted into park it sometimes was is reverse even though the indicator said park and you could turn off the truck and remove the key . The solution was to have the horn blow when you opened the drivers door . Instead of fixing the linkage and or trans . Real bandaid approach . I believe this is how the actor that played Checov in the new Star Trek movies was killed by his Jeep he got out walked behind the vehicle and it pinned him against the wall
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 04-12-2024, 04:45 PM   #7
Micmac
Micmac's Avatar
Mark,
I am lucky that I live across a bridge from Canada. They have good ‘ol’ fashion gas cans at Canadian Tire. I’ve spilled more out of these EPA Cans than got in the tank.
1963 Chevrolet C-10 "Ginger"
1970 C-30 Dump Truck "Scarlet"
2019 Chevy Silverado 2500 Z71 LTZ
1947 Indian Chief Roadmaster with Sidecar.
2012 Indian Chief Serial #002 of 110 built in '12
2016 Indian Chief Roadmaster
Micmac is offline   Reply With Quote
Old 04-12-2024, 06:28 PM   #8
truckster
truckster's Avatar
Originally Posted by Micmac View Post
Mark,
Interesting... I don't live near Canada, but there must be some way to get one.
Old 04-12-2024, 06:43 PM   #9
Micmac
Micmac's Avatar
https://www.canadiantire.ca/en/pdp/s...rq=gas+can#srp
That is 23.23 United States Dollars
I also think you can just buy the nozzles to, look at their website.
Old 04-12-2024, 07:57 PM   #10
CG
BlahBlahBlah
Thread reminded me of this ...
Old 04-13-2024, 08:11 AM   #11
72c20customcamper
Mark,
I tossed the EPA crap “no spill” bought the eagle gas can been great and I have a few racing type cans they work well also
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 04-13-2024, 12:14 PM   #12
kwmech
I recently bought these, no frills and they work without all the crap. I got 4 gas cans and 3 diesel cans to get away from the plastic crap.
https://www.vevor.com/jerry-cans-c_1...p_010629890109
