04-21-2024, 05:17 PM | #1 |
Post Whore
Needing tilt column rebuilder expert advice.
I am going through a tilt column and I found these wear patterns on the tilt yokes (?). It appears that at some time in the past the nylon ball part failed and the car was driven for awhile that way.
Will I be okay if I polish the high spots off and reassembled the unit? And should I replace the current nylon ball assembly or is this one still reliable? It's obviously an older piece but are the current repops any good? I can post more pictures if needed. Thanks in advance for any advice.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
04-22-2024, 09:32 AM | #2 |
Re: Needing tilt column rebuilder expert advice.
That wear is made by the c looking metal piece that is between the nylon ball, when you reassemble the column make sure the ball with the metal piece is on the opposite side of the wear pattern and you will be fine. I hope you understand what I said, if not pm me.
04-22-2024, 12:18 PM | #3 |
Post Whore
Got it! Thank you very much. I hadn't even considered that as an cause.
This place is the best! Thanks to everyone who looked in. Alright time to dive back into cleaning and painting parts! Woo hoo!
