Old 05-02-2024, 01:55 PM   #1
andymiller
andymiller's Avatar
CPP slip driveshaft and billet carrier bearing
I just bought a CPP slip driveshaft and billet carrier bearing, had it balanced. But feels some vibration.
Has anyone had similar issues with either?
I bought a oem style carrier, and going to install to see if the bearing or the shaft is making the vibration
andymiller is offline   Reply With Quote
Old 05-03-2024, 01:23 PM   #2
71 super
71 super's Avatar
Re: CPP slip driveshaft and billet carrier bearing
I used the billet style carrier bearing in my anniversary truck with stock drive shaft and had no problems.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 05-04-2024, 01:40 PM   #3
HO455
Post Whore
HO455's Avatar
I installed the billet carrier and the slip rear drive shaft in my Burban (Not from CPP) It helped reduce vibrations. I ended up having to rebuild the rear end to eliminate more vibrations and then finally found the the pinon yoke was damaged before I got to the bottom of my vibrations.
You may have additional items contributing to your vibrations outside of the driveline.
Is your truck lowered? That can add additional problems with U-joint angles. I was able to further reduce vibration by getting my U-joint angles properly set up. My Burban is lowered.
RIP Bob Parks.
Last edited by HO455; 05-05-2024 at 09:33 AM. Reason: Additional information on the U-joint angles.
Old 05-05-2024, 11:54 AM   #4
andymiller
andymiller's Avatar
I think you hit the nail on the head.
Its lowered 4" in the rear. And this winter, I installed a shock relocation kit.
I'm thinking the pinon angle is low, and the angle at the carrier bearing is steep.
I'm going to tweak some things to see if it helps.
Old 05-06-2024, 12:14 AM   #5
mr48chev
mr48chev's Avatar
I had to read this a couple of times to make sure I was reading it right but the gist of things is that all three U joints need to be on the same plane.
That matches the one piece driveshaft concept of output shaft and yoke on the transmission and the pinion shaft being on the same plane. Time to dig out the angle finder and schooch under it with it sitting flat on the floor.
My ongoing truck projects:
Old 05-06-2024, 08:16 AM   #6
HO455
Post Whore
HO455's Avatar
Spicer has some good videos and this nice calculator for drive line angles.
https://spicerparts.com/calculators/...gle-calculator
Here are some notes from when I was checking mine. Starts on post 348. there is a little bit more on the previous page about the installation.
https://67-72chevytrucks.com/vboard/...698377&page=14
RIP Bob Parks.
