05-03-2024, 05:05 PM | #1 |
Help ID These Brackets
Got these recently in a box of parts I purchased for a couple other things I wanted. Digging thru the box to the bottom I found these. Solid steel rod with both the straight and the 90 degree bend being threaded for a coarse thread body bolt (?). Measured them to be 12 1/4'' in length and the rod looks to be 5/16'' in diameter. Similar to the rear fender support rods on my 71 4x4 but too short for length. Square body rear support rods maybe, not sure as don't have a square body here? Tried a search and probably did not put in the right wording. Any thoughts and ideas would be a help.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
05-05-2024, 02:38 PM | #2 |
Re: Help ID These Brackets
You might be right about them being for a square body
https://classicparts.com/1973-91-bed...e-fleetside-pr |
05-05-2024, 03:30 PM | #3 |
Patrick, those look to be the same with perhaps being an after market brace from Classic Parts the threaded portion of the brace looks like a welded on nut plate. These rods appear to be formed as one piece and then threaded. Thanks for the assist.
