05-14-2024, 05:56 PM | #1 |
Parking brake question
Is it possible to switch from a foot operated parking brake setup on the far left side of the cab, to one of the lever operated ones in the center of the dash?
For reference purposes I have a 1953 1/2 ton five window. The purpose of my question is that I acquired a set of kick panels from Rod Door that are pretty spiffy, but given the pod for a right and left speaker, the left side does not fit because it interferes with the foot operated mechanism. Thanks in advance. Bob
1953 Chevy 3100 - 5 window 1/2 ton pickup My 1953 Chevy Work-In-Process Photo Gallery "I don't have a carbon footprint, I drive everywhere." |
05-14-2024, 06:25 PM | #2 |
Re: Parking brake question
I didn't think the pre 1960 came with a foot operated. in base model truck.
You should just have to put the stock 49-53 parking brake handle rod and lever on frame that is probably still in place. hook up the cables the center pull and you should be good to go. I'll bet a few folks may even have one around and I am sure some guys on stovebolt will have something. |
05-14-2024, 06:29 PM | #3 | |
05-14-2024, 06:31 PM | #4 |
I'd like to understand the intersection between where the foot operated pedal connects to the under cab linkage versus the dash operated version. How and where does the cab mounted handle mount?
05-14-2024, 06:49 PM | #5 |
First forgive me lost my mind on parking brake and years.
Had my other hat on. Of course it had a foot pedal Look at how the 1955.2 to 59 is setup. That may work for what you ar looking for. |
05-14-2024, 06:55 PM | #6 |
The handle is just under dash it has a straight rod thru firewall down to frame rail to a pivot mounted on frame. The pivot is connected via cable to center of underbelly of truck to center pull for both left and right rear cables.
The handle is a pull so it pulls the pivot to pull the cable toward front and engage. |
05-14-2024, 06:59 PM | #7 | |
05-14-2024, 07:04 PM | #8 |
here you go
05-14-2024, 07:05 PM | #9 |
this is the 55.2 - 59 version. in picture in previous post
05-14-2024, 07:11 PM | #10 |
or you could go like the 60s cars had the ratchet style.
just some cabling to work on and setup. |
05-14-2024, 07:12 PM | #11 |
Hmmmmm those are a lot of parts to acquire. I see several of them on Chev's of the 40's but that bill is going to add up.......I need to do more research. Thank you for the picture that helps a lot.
05-14-2024, 07:13 PM | #12 |
'47, maybe '48 and all years of AD cab 1 Ton or larger had a center mount parking brake lever that mounted to the side of the trans. from there a rod ran back to pull on the parking brake cross-bar
people have adapted this same lever to various modern transmissions it is 'farm implement' in style though |
05-14-2024, 07:14 PM | #13 |
Thats an interesting alternative that might be able to work with my existing setup.
05-14-2024, 07:15 PM | #14 | |
05-14-2024, 07:16 PM | #15 |
Where did you find this ratchet style? Was it from a specific make and model?
05-14-2024, 07:16 PM | #16 |
or
https://www.summitracing.com/parts/ado-42563907 and some 1/4' round stock to make a link back to the factory cross bar |
05-14-2024, 07:20 PM | #17 |
you can find the pull style ratcheting ones in toyota pickups 70s-90s
05-14-2024, 07:21 PM | #18 |
the ratchet style was a 63 mustang but there are other version by all kinds of manufacturers
05-14-2024, 07:23 PM | #19 |
Found the same one you posted on Summit for a Mustang. I think that might be able to be adapted easy enough. I'll investigate further
05-14-2024, 07:31 PM | #20 |
the depth of that rod may be different on different version and manufactures.
GM had them in the 150 and other period correct cars as well if you more into keeping in line. But Toyota as well like previously posted may have the right length you need. cable on . |
05-14-2024, 08:09 PM | #21 |
This is a bit more expensive but I'm wondering if anyone has had any experience with an electric hydraulic parking brake. This is effectively what is in three of the cars in our family......park the car, press the button to engage the parking brake.
05-14-2024, 08:36 PM | #22 |
If that is inline with normal brake lines. Good for parking lousy for emergency
You loose a line and fluid it does nothing. There is a reason the parking emergency brake is cable activate |
05-14-2024, 08:43 PM | #23 |
Good point, but then its the same as the three other newer cars in the family. The truck already has been fitted with four rotors and calipers, as well as an electric hydraulic power brake booster.
05-14-2024, 09:45 PM | #24 | |
That bar runs at a bit of an angle across a pad on the frame rail to a clevis.
05-14-2024, 10:21 PM | #25 |
A few GM cars in the early 50's had a pull handle to put the park brake on that went under the dash, usually on the left side of the steering wheel. A lot of Ford cars and trucks that handle and cable that could be worked to work the park brake.
One shot with my doodle on it shows what's left of a park brake rod someone lifted the cab off the chassis of the truck and cut the rod The other one shows the cross shaft with part of a bent up rod and you can see the clevis. Some of the GM ones are far too complicated to swap, OK in their original home but too much work. The TF truck handle has rods and levers going every which way rather than a cable. The simplest would be a floor mounted lever like a ton of cars have either using the cable that was used with the handle or modifying that steel rod to work with the handle. The rub with that is that you have the park brake handle down on the floor board.
