v30 rear suspension help
Hey everyone I need some help.
I have a 1988 v30 single cab dually and the rear suspension has blocks, are these a factory block?
1979 K10 Silverado SWB 1981 K30 Scottsdale Crew Cab SRW 1988 v30 Silverado single cab DRW 1991 K20 Suburban barn door |
![]() Join Date: Feb 2004
Re: v30 rear suspension help
I have the same truck, I’ll look when I get back to the shop…
57, I would appreciate that thank you.
![]() Join Date: Mar 2003
Never seen a square body with a factory block
Mine is an '87 V30 SRW. No block
'72 Blazer, A/C, tach, tilt. Not on the road at this time '87 v30 Custom Deluxe, standard cab, SRW, Utility bed '86 c10 Silverado longbed (for now) '19 ecsb, 2500, 4x4 '15 Subaru Legacy - commuter |
yeah, I'm thinking this my be some cobbled together lift, the front springs are wavy like they are a generic lift spring for a 1/2 or 3/4 ton but not for the weight of a big block.
Active Member
![]() Join Date: Jan 2017
I parted out my 1986 K30 several years ago due to rust - no blocks. It was completely stock when it met its demise.
