Old 05-22-2024, 08:08 PM   #1
'68OrangeSunshine
'68OrangeSunshine's Avatar
'03 Tahoe -- 8-Button Door Switch
The 8-Button Door/Window/Mirror/Lock Switch on my 2003 Tahoe has many glitches.
Window Up/Down functions are iffy. The Drivers window often works OK, but the Passenger side front window is 50/50. Sometimes I have to lean over to move it Up or Down. Occasionally the rear passenger window will go down of its own accord when I start the truck. The rear drivers side just doesn't work.
The Mirror adjusters work OK to set up the Drivers side, but when I move the rocker switch over to do the passenger side, it goes nuts. I'm afraid to mess with it.
The automatic door locks all pop Open when the shifter is put in Park. I understand that's a default setting. PIA when I park Downtown and have to hand check each door for security. That's 5 locks with Barn Doors.
I don't have a remote Key Fob.
Rear doors won't relock from the Driver's button.
I have watched You Tube videos of guys removing door panels to access these switches. Some are clowns. Some know what they're doing. A few are good.
There are EBay maguffins to repair the plastic clips if a PO was an idiot and muscle#ucked the door panels off.
One guy took the 8-Button switch apart and cleaned the contacts with q-tips and alcohol, with positive results.
Otherwise the switch assemblies get spendy. I don't have Heated/Retracting mirrors so I can skip the $151 dollar switch and $200 core charge from RockAuto. I probably want Dorman p/n 901-075 at $112, no core, for the simpler 8-Button switch. A call to O'Reilly's for a price check on 901-075 didn't work, as they'd have to start a Special Order to get me a price.
I have not checked the local U-Pull-It yards yet.
Old 05-27-2024, 02:31 PM   #2
hatzie
Moderator
hatzie's Avatar
Re: '03 Tahoe -- 8-Button Door Switch
You can change the settings to only the driver's door unlocks or none of the doors unlock.
I think you can also change it from when it goes into park to when you take the key out of the ignition.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 05-27-2024, 04:36 PM   #3
'68OrangeSunshine
OK. Thanks. I will get after the switches first. Then I can program locking settimgs. Finally get key fobs and program them.
Old 05-27-2024, 05:19 PM   #4
hatzie
Moderator
hatzie's Avatar
Lock/Unlock personalization settings using the DIC.
Page 3-57 of the 2003 Tahoe Owner Manual
Automatic Locking
Press the personalization button until AUTOMATIC LOCKING appears in the display.
To select your personalization for automatic locking, press the select button while AUTOMATIC LOCKING is displayed on the DIC.
Pressing the select button will scroll through the following choices:
  • LOCK DOORS OUT OF PARK (default): The doors will lock when the vehicle is shifted out of PARK (P).
  • LOCK DOORS MANUALLY: The doors will not be locked automatically.
  • LOCK DOORS WITH SPEED: The doors will lock when the vehicle speed is above 8 mph (13 km/h) for three seconds.
Choose one of the three options and press the personalization button while it is displayed on the DIC to select it and move on to the next feature.
For more information on automatic door locks see Programmable Automatic Doors Locks.
Automatic Unlocking
Press the personalization button until AUTOMATIC UNLOCKING appears in the display.
To select your personalization for automatic unlocking, press the select button while AUTOMATIC UNLOCKING is displayed on the DIC.
  • UNLOCK ALL IN PARK (default): All of the doors will unlock when the vehicle is shifted into PARK (P).
  • UNLOCK ALL AT KEY OUT: All of the doors will unlock when the key is taken out of the ignition.
  • UNLOCK DOORS MANUALLY: The doors will not be unlocked automatically.
  • UNLOCK DRIVER IN PARK: The driver’s door will be unlocked when the vehicle is shifted in PARK (P).
Choose one of the four options and press the personalization button while it is displayed on the DIC to select it and move on to the next feature.
For more information on automatic door locks see Programmable Automatic Door Locks.
Aftermarket driver door switch modules are around $100-$150 from RockAuto. You may be able to disassemble them and clean up the contacts but they tend to be very brittle after 22 years.
If you want to buy used you need to pay attention to several options. Power folding and tow mirrors among other things.
Old 05-27-2024, 06:41 PM   #5
'68OrangeSunshine
Thanks.
Is the DIC the digital scroll on the dash that usually displays the Odometer setting?
Old 05-27-2024, 08:17 PM   #6
hatzie
Moderator
hatzie's Avatar
Originally Posted by '68OrangeSunshine View Post
Thanks.
Yup. My truck has the buttons in the steering wheel to access those menus.
The trucks without those buttons have other ways to get into them.
Old 05-27-2024, 09:45 PM   #7
'68OrangeSunshine
I think you have to play games with the Brites Lever, the IGN Sw and the Door Lock/Unlok buttons.
Since that switchbox is screwy, I'll hafta wait.
Old 05-29-2024, 09:58 AM   #8
hatzie
Moderator
hatzie's Avatar
Another option is to install a steering wheel with buttons along with the matching clockspring.
There's a thread on the Avalanche forums about how to go about doing this. And there's more in-depth stuff on some of the Tahoe forums about changing the inner workings of the instrument panel software. The button wiring is supposedly already present in the column. Similar to adding cruise control in the 95-01 T400 by swapping the stalk.
The instrument panel may need to be reprogrammed for additional DIC menu items but it should give you access to the ones that are already there a lot easier.
If you want the radio buttons to work you'll need to reprogram the BCM, that gets a little more difficult. A dealership Tech could conceivably change the BCM programming but I'm not sure how much GM is willing to allow. I don't think there's a lot of information on reverse engineering the BCM software like there is for the instrument panel.
Old 05-31-2024, 05:15 AM   #9
'68OrangeSunshine
Radio works OK for local FM. A disc is stuck in the CD Changer, and I haven't found a good cassette to test that with.
I thought the A/C was busted -- only blowing Hot, but I looked at the Manual, and I had to push a couple of tiny buttons to get it to cool. Not blowing ice cubes, but materially cooler than ambient.
Not interested in a steering wheel swap anytime soon.
But I did see a You Tube clip about a guy who got an Escalade Dash Package and he was able to just pull out the old one on his Silverado, and plug and play the new one. Don't really need a 140 MPH Speedo, but Trans Temp was a cool upgrade. Only cost him north of $400
Old 06-02-2024, 09:35 PM   #10
'68OrangeSunshine
New glitch just popped up:
DRIVERS DOOR AJAR
When it's clearly shut. Opening the door and slamming it shut -- at a light -- has no effect.
Also Cabin lights stay on, too.
What herb is recommended as a Gremlin Bane?
Old 06-04-2024, 12:05 PM   #11
hatzie
Moderator
hatzie's Avatar
The side door ajar switchs terminate with the door power window, lock, mirror switch panels.
The switch states are sent from there to the BCM over the Serial databuss.
They control mirrors, mirror lights, and courtesy lamps in the door as well.
Time to get a replacement door switch module.
Take a picture of your SPID label on the glovebox door so you can look at the RPO codes.
Some of the Dorman switch modules are remanufactured with a $200 core.
RockAuto 2003 Chevy Tahoe power window switches.
Old 06-04-2024, 11:10 PM   #12
'68OrangeSunshine
My Tahoe does not have Heated Mirrors. or blinking arrows. Pedals are non-adjustable.
RockAuto looks like the best deal. Dorman 901-175 for $+111.79 and No Core charge.
LMC and Jegs seem to have higher prices and core charges.
I'm not sure what RPO code is applicable. Is there an RPO Decoder anywhere?
I will try attaching my SPID...
Old 06-05-2024, 05:03 PM   #13
hatzie
Moderator
hatzie's Avatar
https://decoderpo.com/
DL8 = PIO, Mirror, outside left-hand and right-hand heated dual remote 17" heads
PIO, Mirror, outside left-hand and right-hand with integral convex mirrors, heated, dual remote controls, (Port Installed Option)
MIRROR,OUTSIDE,RH AND LH REMOTE CONTROL,ELECTRIC,DEFOG
Looks like the original purchaser bought the DT4 smoking package too.
Old 06-05-2024, 06:32 PM   #14
'68OrangeSunshine
The mirrors don't look like 17'' heads.
The Cigar Lighter does work, but I think the Ash Tray is long gone. Just deep storage pockets under the A/C controls. Funny, I could not get 12 vdc out of the Cigar Lighter socket. That is, the accessory plug from my GPS wouldn't fit. It fit the Aux Power port to the right however. And there's another Aux port behind the front seats. Easy enough to run an accessory cord USB--USB-C for cell phone charging.
Having ''Heated Mirrors'' might change my RockAuto order. I didn't want to deal with cores and charges.
Thanks for the RPO translator. I put in the whole sequence and saved it, I think.
Old 06-05-2024, 10:01 PM   #15
'68OrangeSunshine
What does [PIO] Port Installed Option mean?
Old 06-07-2024, 08:45 PM   #16
hatzie
Moderator
hatzie's Avatar
Dealer installed option.
The dealer installs whatever it is and gets a new program for the module to allow control of said options.
Old 06-08-2024, 03:23 PM   #17
'68OrangeSunshine
I took a tape measure to my RVM. It was about 11'' of glass not 17''.
So maybe a PO had them removed?
Old 06-08-2024, 05:05 PM   #18
hatzie
Moderator
hatzie's Avatar
Those look like my heated power folding mirrors with the turn signal in the glass
Old 06-08-2024, 06:42 PM   #19
'68OrangeSunshine
No Turn Signals [working] in the glass. They might fold back. I don't know how to make that so.
Heated mirrors in AZ?
Not 17''.
Old 06-09-2024, 09:32 AM   #20
Wootdog
Wootdog's Avatar
Normally,
I don't buy electrical type things second hand. But with as expensive as you are saying this is: Have you tried Car-Parts.com? It is a nationwide site of Salvage Yards across America. They rank the parts, tell you exactly what it is and also tell you have far from you the parts are. I have used them in the past and bought a whole radiator support for a second generation Camaro I use to have.
V/R
Kerry Aka Wootdog
1969 Chevelle
1990 IROC Z Convertible
2002 Silverado LT
Wootdog is offline   Reply With Quote
Old 06-09-2024, 04:50 PM   #21
'68OrangeSunshine
Originally Posted by Wootdog View Post
Normally,
V/R
Kerry Aka Wootdog
Thanks for the tip, Kerry. I'm not so sure I would trust a sensative electrical part as the 8-button switch to survive over two decades in a junkyard.
Cheapest fix I've seen on YouTube was a guy took the switch assembly out, and dissassembled it down to the printed circuit board. He then cleaned all the contacts with Q-Tips and alcohol and put it back together. Once all buttoned back up, it worked flawlessly.
It could work, or it could get screwed up permanently. If I pull the switch out, and it gets FUBAR, the whole truck is down until the switch is replaced.
I think I bought an SI-12 Alternator [w/internal Voltage Regulator] for my '71 GMC Jimmy from Car-Parts.com. New component. Had a 2 year warranty. Still working fine several years later.
Old 06-09-2024, 05:15 PM   #22
'68OrangeSunshine
OK. I checked Car-Part.com online.
>Riteway Auto Parts in Phoenix had an 8-Button switch from a 2004 Suburban for $305.
>Late Model Auto Salvage in Ft Worth TX wants $369 for theirs from an '03 Tahoe.
The outfit I bought the Alternator from was Car-Parts.com [with an S]. I had some rebate deal thru my bank if I used my debit card. Not the same guys.
RockAuto is still the cheapest.
Old 06-10-2024, 11:55 AM   #23
hatzie
Moderator
hatzie's Avatar
Owch
Years ago I shopped a used starter for my VW Rabbit diesel. I could get one remanufactured for $85 or I could get one Salvage for $150. Guess which one I bought LOL
I ought to go over to my buddies place and see if he's got one in the Avalanche the crew cab or the Suburbans he's got out back.
