05-23-2024, 05:58 PM | #1 |
Location: 3,018 feet above the SoCal/Mojave Desert region.
1972 california commercial license plate.
So for us Californians trucks are registered as commercial and have different plates.
For a passenger vehicle in '72, the format would be 123 ABC. My '72 C10 format is 1A12345 on blue plates. My question is, is that the correct format for a '72 truck?? I tried researching DMV and on line. Can't find anything. How far back did commercial plates for pick up trucks go? I know that the letter can be elsewhere instead of the second character on the plate. Last edited by desert-rat; 05-23-2024 at 11:05 PM. |
05-23-2024, 06:09 PM | #2 |
Who Changed This?
Re: 1972 california commercial license plate.
They were ##_###_ 'Letter' where _ is a space. Black with yellow letters from '63 to '70, and blue with yellow letters for yours. I don't recall what format the plates were prior to '63, but there were indeed commercial plates before then. I do know that '55 to '62 plates were yellow with black characters. Is your license plate white? I'm not familiar with the car/truck format for those.
05-23-2024, 06:46 PM | #3 |
At the body shop.
Pop moved here in june 71
It was xx219 J when they re-registered it. I've yet to find a pic of the entire sequence. Black plate yellow character
" That didnt make it any newer " " Dont antique the equipment " |
05-23-2024, 06:46 PM | #4 |
The original Cal plates on my '68 C/10 Stepside [bought 6/73] were Black w/ Yellow digits:
10 566 A Note the spacing. When I registered the truck in Arizona in 1974, I had to surrender the Cal plates to the MVD, who returned them to the DMV. [By military regulations, my vehicle registration had to match my drivers license by state] I might have a '50s Cal commercial plate in my garage. It's Yellow w/ Black digits. I'll look later.
05-23-2024, 07:37 PM | #5 |
Who Changed This?
The black with yellow commercial plates were used until the local DMV offices ran out. Small towns could have had a lot of them in stock.
05-23-2024, 09:05 PM | #6 |
My ‘71 is an original San Diego truck with black and yellow.
Smitty '71 Short Fleetside Spring Valley, Ca. |
05-23-2024, 09:24 PM | #7 |
20' Daredevil (Ret)
That's the exact format of the original California plates on my '72 (Fremont) K20, including the colors. They are still on the truck.
05-23-2024, 09:36 PM | #8 |
I'm not sure if adds anything to this thread, but here is a picture of the plates that were issued in Orange County for my new '69 truck purchased and registered the last week of November, 1969.
Jim |
05-23-2024, 10:14 PM | #9 |
Who Changed This?
Case in point, though I'm kind of surprised that the black/yellow plates were still being used in '72. Given the strange things we see from year to year with our trucks, I shouldn't be surprised, I guess.
05-23-2024, 11:13 PM | #10 |
I had a 74 truck in Ca. it had blue with yellow letters/numbers and plate was 1L26450, or close to it.
Bob |
05-24-2024, 12:38 AM | #11 |
At the body shop.
If you're purchasing plates check for back registration fees prior to purchase.
I bought this pair. And they have 547 in fees to re-register. https://www.dmv.ca.gov/portal/handbo...icense-plates/
05-24-2024, 10:13 AM | #12 |
In California a c10 does not require a commercial plate. All c20 require commercial unless a permanent camper was mounted. If a c10 has commercial plates it is because the truck was likely registered in a corporate name and used as a commercial vehicle. If you have a c10 registered as commercial you can save a few bucks a year by changing to private.
05-24-2024, 11:01 AM | #13 | |
20' Daredevil (Ret)
For instance, if your truck has a tonneau cover or a camper shell, you can get non-commercial plates.
05-24-2024, 11:15 AM | #14 |
The CA title on my C/10 says COMMERCIAL on it. For some reason, it's got blue & yellow plates. My assumption is that it spent the first few years as a government vehicle (CalTrans), in which case it would have had exempt plates that were then replaced with regular plates when it was sold off. My blue & yellow plates are 66 069 L. From what I've found, the L series is from approximately 1972.
05-24-2024, 12:37 PM | #15 | |
At the body shop.
Camper shell or bed cover can get car tags with hoops to jump thru
05-24-2024, 01:37 PM | #16 |
Who Changed This?
Even a Chevy Vega Panel "truck" has to have commercial plates. I bought one, and if I had known before I went to the DMV, I'd've popped the panels and put in some windows that I had. My 3/4T truck is registered as a "housecar", so has non-commercial plates. This required bed(s) and a toilet, as a minimum, as well as a "permanent" camper shell- bolted on, as opposed to easily removed with camper jacks.
05-24-2024, 02:14 PM | #17 | |
20' Daredevil (Ret)
Also FWIW -- mine is an early '72, built in August 1971. No idea when it was sold and first licensed, though.
05-24-2024, 03:16 PM | #18 |
Who Changed This?
Plates are distributed across the state to DMV offices, so it could be tough to tell what year a plate got matched with a truck.
05-24-2024, 03:52 PM | #19 |
Definitely a lot of variation out there. Here are some commercial plates I found on Craigslist.
05-24-2024, 04:11 PM | #20 |
I bought my '87 G20 van from my neighbor after he was using it for landscaping and it had commercial plates, one letter and rest numbers. It now has regular passenger vehicle plates 1ABC123 but the DMV said had to mount at least one seat and belt in the back for passenger plates. It has a folding rear bench now that folds flat. DMV had to inspect it in order to change registration and plates over to non commercial.
05-24-2024, 04:12 PM | #21 |
05-24-2024, 05:14 PM | #22 |
Who Changed This?
Hah! I saw that Dodge van on there just yesterday!
05-24-2024, 05:58 PM | #23 |
Typically (not always) 72 trucks came with
Blue and yellow plates The last digit was K L M N O, sometimes P 71 trucks (usually ) would have ended H I J 73 ended in P or above Much of this depended what county the truck was originally registered in I've had 72 trucks registered in a rural counties That had Black and yellow plates ending in J (Most likely because that DMV office didn't use up their commercial plates as fast as a DMV in a populated county would) Hence, why most 72's came with BLUE and ended with K or greater |
05-25-2024, 09:45 AM | #24 |
05-25-2024, 10:38 AM | #25 | |
At the body shop.
I've always figured dad didn't re register the 68 until he had to. Hence the black J plate on it. I finally quit looking for a pair and got a personalized black plate. Also seems like for hire commercial trucks. Began with a single letter where a pickup ends with a letter.
" That didnt make it any newer " " Dont antique the equipment " Last edited by KQQL IT; 05-25-2024 at 10:50 AM. |
