Old 05-27-2024, 08:01 AM   #1
Ricks1971
Ricks1971's Avatar
putting a aftermarket oil pressure gauge
Looking for a little help? I am putting a aftermarket oil pressure gauge and need to know what fitting you guys use to connect them behind the block?
Ricks1971 is offline   Reply With Quote
Old 05-27-2024, 10:03 AM   #2
72c20customcamper
72c20customcamper's Avatar
Re: putting a aftermarket oil pressure gauge
The kits come with everything you need to install the gage . Don’t use the supplied plastic tubing buy the copper . I just put one in my 72 on the new motor
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 05-27-2024, 11:09 AM   #3
Extended Power
Extended Power's Avatar
I went with an electric pressure gauge because I didn’t want an oil line, copper or not, inside the cab.
Here are some screen shots of what I had posted.
"If it ain't broken, fix it 'till it is!"
Extended Power is offline   Reply With Quote
Old 05-27-2024, 01:32 PM   #4
Ricks1971
Ricks1971's Avatar
I am still going to run the stock one in the dash cluster and going to use a under dash autometer oil and temp gauge. Going to use the same spot on the back of the block but need a fitting that has 2 outlets?
Old 05-27-2024, 01:44 PM   #5
RustyPile
RustyPile's Avatar
You'll probably have to use a TEE with a short pipe nipple.
RustyPile is offline   Reply With Quote
Old 05-27-2024, 04:00 PM   #6
72c20customcamper
Or use another oil port . The one under the distributor isn’t easy to access. I used the one on the front over the timing cover for the stock electric unit on my 85 . It already had a mechanical hooked up under the distributor. There is also a port just above the oil filter boss on most Chevy v8s . Both would be a lot easier to access if you’re running two . I made a bracket for the sender so it didn’t vibrate . No leaks after three years
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 05-30-2024, 12:15 PM   #7
MikeB
MikeB's Avatar
The oil pressure port behind the intake manifold is 1/8" NPT.
Lots of tee fittings to choose from: https://www.amazon.com/s?k=1%2F8+npt+tee+fitting
You may also need a section of straight pipe to raise the tee.
Not all blocks have an oil pressure port above the timing chain cover, but most have a port just above the oil filter.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 05-30-2024, 01:23 PM   #8
72SB
OP, if its a SBC there should be a NPT plug above oil filter you can use for the electronic sender. Some headers can be a conflict with that port.
To maintain the stock sender but use that same port, a combo of 1/8 NPT fittings to allow both senders to occupy that space. Due to headers, I had to come up with a combination for this and also clear the coil mounted on my intake manifold. straight, 90 and 45 degree fittings are available on Amazon and some auto part stores
72SB is offline   Reply With Quote
Old 06-08-2024, 11:24 AM   #9
raggedjim
raggedjim's Avatar
I have to add this about the plastic line. I was driving my 73 Firebird yesterday and the plastic line split and by the time I got to a place I could stop there was oil in my boot, on my pants, and all over the windshield and dash. The line was probably 6 years old.
I'm changing out for a wired pressure sensor...
Good luck, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 06-08-2024, 04:50 PM   #10
72c20customcamper
Good luck, Rg
Never use the plastic tubing you’re just looking for trouble. Pretty sure most of the trucks that have mechanical factory gages still have the original copper lines .
It’s against building code here to use plastic tubing going to the fridge for the water and ice . That should tell you something
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 06-09-2024, 01:45 PM   #11
MikeB
MikeB's Avatar
Yes, my original line and gauge worked without leaks for 44 years, When I replaced it with an electric sender and gauge, there were signs of a slight oil leak in the gauge fitting, but not even enough to form a drop.
Mike
