Almost Satisfied
![]() Join Date: Mar 2002
Stepside Tailgate...no chains...how?
I have seen a couple of the kits that allow you to get rid of the chains. Are any of you using one of these kits?
I would like to see some pics of your set-ups on how you latch the gate without chains. Also, how did you remove the angle pieces on the tailgate and bedsides without destroying the pieces?
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
Yes sir!
I cut it all off! replaced the top right corner with a small angle bracket w/ a hole for a pin to go through into the Bed. The pin has a socket type ball on the end so it stays in the Bed hole witch keeps the tail gate up! Very simple Once I lost the pin and had to use a tree branch to hold it up till I got home! Cheers Check the www ![]()
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
![]() Join Date: Feb 2001
I like this........
I believe there will be times you will want to open your tailgate.
You can also weld some seat belt clips on the inside so they click and latch when closing
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
you take the pin out by pushing it in which releases the socket ball and down she comes!
And the leather strap on the other side stops the fall!
" SHOW ME"
did anyone see those tailgate arms on trucks , m not for sure if he was putting them on copperhead or not, they were electric arms that ran by the flick of a switch and you could also open it half way while driving so youre gate would work like a spoiler , i dont see any reason you couldnt run em on a step
Almost Satisfied
I would like to find something that is hidden. I expect to have a knob or something that shows so you can unlatch the gate, but I want the straps hidden. There has to be something on the market for this considering the step bed has been around forever and the chain set-up is virtually the same for all of them.
Keep the ideas coming and thanks for what you have posted so far.
check out wow-products.com
Thats what Im planning to get for mine. John
75 GMC C-15 short/step factory 454, lowered |
i believe www.mar-k.com has something like that.
That wow-products kit looks pretty decent, looks like a winner. Too bad I didnt find that site before I started fabricating my tailgate.
BTW to get the chain latch brackets off, I think destroing them is the best way to go. We just cut what we could and grinded the rest of material flush.
Craig Berland |
Weld up in the piece on the tail gate and on the bed where the brackets went through.
Craig Berland |
Almost Satisfied
I'll check out those two sites. Thanks
I think you are right cb...they will just have to be cut off and grinded down. I just wanted a tailgate latch assembly first so I had the best plan of attack before hacking into my $400 a piece new bedsides!! LOL
