Old 01-23-2004, 11:58 AM   #1
Bluegoose972
Skid Plate....Needed?
There is another crossmember located about 12" behind the crossmember that holds up the transfer case in my blazer. It has no function other than to hold up half of the flat skid plate that spans between these crossmembers.
Here is my question......Was this a factory option or does everyone have this same setup on their blazer? I'm considering NOT installing this crossmember and skidplate. After seeing the amount of material that builds up on this plate, I really don't see a good reason for it. I don't plan on doing anything where I'll high-center, especially with 6" of lift and 36" tires. Is there a reason I shouldn't remove this skid plate and cross member?
Rick
Bluegoose972 is offline   Reply With Quote
Old 01-23-2004, 03:28 PM   #2
badpeanut
Not a bad nut after all..
badpeanut's Avatar
The transfer case skid plate was an option (the second crossmember and actual plate are a package deal). Most trucks didn't have the transfer case skid plate, so they also did not have the second crossmember (or holes for it). ie. you can leave the second crossmember off if you so desire.
Out of curiosity, do you also have the gas tank skid plate? What does you glove box sticker list in regard to skid plate options (are the skid plates listed seperately or together)?
badpeanut is offline   Reply With Quote
Old 01-23-2004, 03:48 PM   #3
Bluegoose972
I'll look when I get home. Yes, my truck has the gas tank skid plate. Unfortunately, the previous owner decided to mount a trailer hitch on the back so he cut a large chunk of steel out of the center of the skid plate. I'm going to try and patch over this piece this weekend. I'm not even going to try and splice it, but actually just weld a new place right over the top and cover the whole. That way I can just clean up the side welds and then repaint it.
Old 01-23-2004, 06:47 PM   #4
1969 GMC
1969 GMC's Avatar
my truck doesn't have the transfer case skid plate, but it does have the 2nd crossmember with a skid plate. is it to protect the front half of the driveshaft?
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 01-23-2004, 07:05 PM   #5
Bluegoose972
Too funny....Good Point 1969GMC.....I need to look more closely at things. Maybe the crossmember was suppose to install in FRONT of the transfer case crossmember. It still really wouldn't help me out a whole lot, other than to collect mud and such. When I pulled things apart, there was at least 3" of mud and grease built up on the skid plate.
Old 01-25-2004, 03:41 AM   #6
1976K5CHALET
1976K5CHALET's Avatar
6 inches and big tires won't save the transfer case....i,ve actually bent the lip on the xmember even with a skid plate...but it all boils down to what kinda wheelin you plan to do...
DW
Doug Wright aka K5NUTT over @coloradok5.com
Owner of http://groups.yahoo.com/group/ChevyK5BlazerChalets
Certified K5 Nut
1976K5CHALET is offline   Reply With Quote
Old 01-25-2004, 02:31 PM   #7
Dan72cst
Dan72cst's Avatar
Just for information.
My BLAZER lists one skid plate option and has the extra cross memeber, t-case plate and the gas tank cover.
INA410 SKID PLATE
Marysville, WA (Dan72cst@hotmail.com)
72 4wd Blazer CST 350/350
72 4wd Chevy LWB 350/350
68 2wd Chevy LWB 327/400
Dan72cst is offline   Reply With Quote
