Old 03-20-2002, 05:17 PM   #1
jjg
Post What kind of motor do i have
hey guys i know there is site i can check this but i have forgotten it so if one of you could decode the number i would greatly appreciate it. I got this on the back of the block on the drivers side.
3970010
thanks
John
jjg is offline   Reply With Quote
Old 03-20-2002, 05:22 PM   #2
wrathchild
LIKE 'EM BIG AND TOPLESS
wrathchild's Avatar
Post
That # is either a 350 or 327..you need the # from front of passenger head to decode any deeper info..
<A HREF="http://communities.msn.com/OurMudToys
I" TARGET=_blank>http://communities.msn.com/OurMudToys
</A>
Check out my '70K5Blazer 350/205 (project 35"BOGGERS)4"suspension/3"body installed,starting bodywork&paint
86K5BLAZER 454ci.350/205 case 4" susp.,3"body 3/4ton4.10s 38"Swamper sx
83CJ-7 304ci.edelbrock 600 and performer intake ,headers 31"Swamper sx
'86 GMC plowtruck (BOSS V-PLOW)
"Welcome to where time stands still
No one leaves and no one will
Moon is full,never seems to change
Just labeled MENTALLY DERANGED..."
"THE INTIMIDATOR" gone but never forgotten !!!
[This message has been edited by wrathchild (edited March 20, 2002).]
wrathchild is offline   Reply With Quote
Old 03-20-2002, 05:25 PM   #3
wrathchild
wrathchild's Avatar
Post
http://www.nastyz28.com/
</A>
Old 03-20-2002, 07:54 PM   #4
Fast68Chevy
Fast68Chevy's Avatar
Post
all we can really tell you- without the stamping code off the front- is that its a 69-79 block and is 4 bolt if its a truck block(stamping code wil tell you that much)
the pad to look for and clean off is just above the timing cover
-71/C-10(thx teeitup and crews!)350 4+4/CH465(thx 71Chev, GMCPaul, and CPNE)longfleet bed(thnx meathead95)!still building it-
-'84 Z28(Z28) 1G1AP87GXEL100000 with H.O. 305/4bbl/190net/hp(L69) 3.73 rear(GT4/YC4) 700R4(MD8-MXO) & other goodies
-79 G20 pass van, 350/th350/10bolt,
paint is overrated
Randy- Lincoln, IL
randy@ccaonline.com
© RSS Enterprises 2000
Fast68Chevy is offline   Reply With Quote
Old 03-20-2002, 08:00 PM   #5
69 longhorn
Post
3970010 is for sure a 4 " bore....as far as 4 bolt main,chevy did some different stuff through the 70s. A 3/4 ton ,or a 4x4 should be a 4 bolt,but a 1/2 ton is a story of its own..........69 longhorn
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 03-20-2002, 08:13 PM   #6
kaycee
kaycee's Avatar
Thumbs up
My book show's it as 67-76 350 or a 302 came in 2 or 4 bolt mains.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 03-20-2002, 11:31 PM   #7
jjg
Post
thanks guys for the info the guy i got the motor from said it came out an early 70's el camino so he might have been right it sounds like, well i will check the numbers by the timing cover tomm, and hopefully will give some more info. i will post the numbers i find.
thanks again.
John
