Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1988-1998 GMT400 Chevy & GMC Pickups Parts Board
Old 12-28-2000, 12:38 PM   #1
Blue'66
Post '91 S-10 Running too Cold
A good friend called me up asking to put a thermostat in his 1991 S-10 w/2.5 and 5 speed. It would'nt heat up enough to make good heat. So I put in a 195 degree T-stat, and road test. No difference, the guauge will move about a eighth of a inch off the 100 degree mark and stay there.
Outside temp is about 10 - 15F
Even in the summertime, the truck hardly warms up. Only time is reaches normal range is idleing in traffic with the A/C on.
Any suggestions?
Thanks all
'48 1/2 ton 3100
'55 1 1/2 ton 4400
'59 Willy's CJ-5
'65 3/4 ton 4x4
'70 C-10
All drivers, no show trucks.
Blue'66 is offline   Reply With Quote
Old 12-29-2000, 01:52 AM   #2
Adam
Post
Are you talking about actual verified tempertature with a separate mechanical gauge? If you're just going by the factory electronic dash gauge-forget it. They are all junk. Temp is probably fine-gauge just doesn't show it.
'93 1/2-ton Cheyenne 2wd
408" smallblock with vortec heads, 9.2:1 CR, Performer Intake, 454 TBI, Comp Cams XE268H cam, custom chip, Thorley headers/true dual exhaust. 375-400 HP. 4L60E w/ Trans-go kit.
408" smallblock with vortec heads, 9.2:1 CR, Performer Intake, 454 TBI, Comp Cams XE268H cam, custom chip, Thorley headers/true dual exhaust. 4L60E w/ Trans-go kit.
Adam is offline   Reply With Quote
