Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 67-72
Closed Thread
Old 02-24-2004, 03:00 PM   #1
jorgensensc
jorgensensc's Avatar
Relay wiring for Headlights???
I can't seem to find the diagram I am looking for for the Headlight relay conversion. I am installing the H-4 conversion from Rick's (great product) and need to know exactly how many and which relays to use. I have a couple of relays that are 4 prong, do I need 2 for each ligh (hi/low)?? Or do I need to get the 5 prong with the 87a terminal and run the 87 terminal to one light and the 87a terminal to the other light and use a 2nd relay for highs? Thanks in advance for the info. I will be posting picks of the original lights and new lights installed with and without relays.
Also, does anyone know which relay to use so the interior dome light will fade out slowly (like newer vehicles) when the door is closed? Thanks in advance!
Thanks,
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline
Old 02-24-2004, 03:56 PM   #2
Alex Hayley
Here is a link that was posted a week or two ago...
http://www.classictruckshop.com/club...ead/lights.htm
Alex Hayley is offline
Old 02-24-2004, 04:40 PM   #3
67chevemall
67chevemall's Avatar
http://www.madelectrical.com/electri...adlights.shtml
This site is great@!
http://www.madelectrical.com/index.shtml
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline
Old 02-24-2004, 05:02 PM   #4
neonlarry
neonlarry's Avatar
You need to use SPST relays either 4 or 5 terminal, 5 terminal just has two 87 terminals. The 87A terminal is on the SPDT relay. Use one relay for low beam one relay for high beam both lights to same relay. Go to this link and click on "Click here to view catalog page"for a terminal diagram.
http://order.waytekwire.com/CGI-BIN/...7D7B71+M37+ENG
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline
Old 02-24-2004, 06:17 PM   #5
jorgensensc
Thaks guys, that's what I'm looking for. Neonlarry, did you ever figure out the dome light dimmer relay??
Thanks again.
Shawn
Old 02-24-2004, 07:30 PM   #6
neonlarry
neonlarry's Avatar
No, I haven't figured out the dome light. Give me a couple of year, make and model with them and I'll see what I can find out . I'd like something like that also to go along with the wiper delay switch I'm putting in.
Old 02-24-2004, 08:05 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Good link, good drawings, good reading.
Longhorn Man is offline
Old 02-24-2004, 10:44 PM   #8
crazy4chevs
crazy4chevs's Avatar
heres annother one.
70 chev c10 swb fleet
72 grill, sb 400, 2/4 drop.
68 chev c10 swb fleet
Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C
Classic GM Truck Club of Washington
crazy4chevs is offline
Old 02-25-2004, 12:53 AM   #9
neonlarry
neonlarry's Avatar
Here is a link to a circuit diagram.
Most all the parts should be available at radio shack.
Old 02-26-2004, 12:18 AM   #10
67chevytodd
Junior Member
Wink Relays
I was able to find the relays at radio shack for $6 bucks a piece
Old Chevys never die they are just reborn!
67chevytodd is offline
Old 02-26-2004, 01:13 PM   #11
1-PU70
1-PU70's Avatar
Call 1-866-866-1315 autothisworld I think that have the fading dome light I know they have the one touch up and down for power windows for $39.99. If they dont check some street rod mags. I know I saw it.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline
Old 03-07-2004, 03:58 AM   #12
Brad
Out of the carpool lane.
Brad's Avatar
I finally got around to doing the headlight conversion on my truck today. I live in a big city with lots of street lights so it's kinda hard to tell the difference but I think there's a little more light now. I haven't had a chance to flip on the high beams and I'm curious how they will look now. Btw, if it's still not enough light after I readjust my lights, I've got a box with the H-4 style lamps with 85/100 watt beams!
I wanted to do this on my practice vehicle (my truck) before I do this to my Camaro. Not too difficult, just took about 1/2 a day and some connectors to make everything look stock.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline
Old 03-07-2004, 03:01 PM   #13
Brad
Brad's Avatar
here's another link headlight upgrade
Brad is offline
Old 02-22-2005, 09:19 PM   #14
71Shortbed
71Shortbed's Avatar
Dome light dimmer
I got a dome light fader from Web Electric.
http://www.webelectricproducts.com/products.htm
It works great. Model DLD-1 Dome Light Dimmer Module. I installed it next to the fuse box and hooked into the dome light wiring right there. I also installed two under dash lights to light the footwells and hooked them in. Lights fade out in twenty seconds when the door is closed but go out instantly when the key is turned or the truck is running. I didn't have doorswitches so I installed them in the rubber bumper holes at the top of the doors... much easier to wire and no drilling.. Drilled out the bumper and it fit over the switch too.
71Shortbed is offline
Old 02-22-2005, 11:13 PM   #15
Harry's 71 C-10
I got mine from Radio Shack. The numbers are listed on the bottom of the relay and on the back of the package.
12VDC/30A SPST Automotive Relay
$6.29
Catalog #: 275-226 Model: 275-226
Harry's 71 C-10 is offline
Old 02-22-2005, 11:23 PM   #16
tnblazerk5
User #12137
tnblazerk5's Avatar
Originally Posted by john_doe
Can the headlight relays be found in the junk yard? And are the numbers 85, 86, 87, 30 found on the relays like in the drawing by crazy4chevs? Thanks.
yes they can you just have to look for them !!! although i didnt use the ones i got from the yard for headlights i used it for elect fans
now i am woundering if i can find the rite kinda thingy for the timed dimer dome lights ?
tnblazerk5 is offline
Old 02-27-2005, 10:31 PM   #17
badpeanut
Not a bad nut after all..
badpeanut's Avatar
For those that have used the Radio Shack style relay, did you mount the relay to the radiator support with a self tapping screw and then use crip on wire connectors to attach to the relay? Anybody have any ideas to make this neater?
badpeanut is offline
Old 02-27-2005, 10:42 PM   #18
Longhorn Man
Go to the junk yard, look on the drivers side firewall on a square body fuel injected S-10. Grab the two relays, and cut the harness a good 6 or 8 inches down. Now the splices you'll make will be hidden and protected in the harness, and the connector will be water tight.
Old 07-28-2005, 03:22 PM   #19
Tanker350
If you have a GMC where we have 2 of each head light where Chevy has 1 of each head light, do we need 4 of these relays? Or is it not possible with GMC's?
Tanker350 is offline
Old 07-28-2005, 06:16 PM   #20
Blue68
Blue68's Avatar
Tanker,
The concept is the same. One relay for low beams, one for the high beams. Only your wiring will be slightly different....I'm guessing not knowing the wiring diagram.
http://home.comcast.net/~r.landrum/w...tos.html-.html
'68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades.
Blue68 is offline
Closed Thread
