Old 03-20-2002, 09:57 PM   #1
dropped72shortbed
Question welding up bumper bolt holes and rechroming?
im going to buy a new front and back bumper unchromed come june and weld up the brackets to the back of the bumper and then weld the holes shut. then ill have them rechromed. is there any special method to doing this so that the chrome wont peel over the weld?
Blake A. - Huntington Beach CA
72 c10 swb
5/5 drop, 350/350, partialy shaved, soon to be 5/7 on 20s.
dropped72shortbed is offline   Reply With Quote
Old 03-21-2002, 12:39 AM   #2
baggedblaz
Post
i'm in the process of this but instead of welding the brackets i welded studs to the bumpers i used square shanked bolts that fit the holes and welded the face and around the back the main thing is the front has to be smooth and free of air bubbles or pits ,you have to find a shop that triple plates or at least copper plates first then some of the pitting can be covered and the chrome sticks better no flaking or peeling .
the bracket thing is ok if you have smaller bumpers the studs give you a little more alignment.
good luck !
i have pics if you want to see some of the bumpers after we welded them?
'82 chev swb 4dr 2wd project
'72 2wd blazer LT1/4L60E "SURFSIN" bagged 20's
'71 2wd blazer
'95 chev 2wd Xcab swb
baggedblaz is offline   Reply With Quote
Old 03-21-2002, 01:16 AM   #3
dropped72shortbed
Post
let me check if i understand correct. you got some bolts with a square head and welded the square head in place of the hole in the bumper? you welded from the back of the bumper right? and then you used the bolt to bolt in on the brackets. did you weld the brackets to the bumper as well or are they just attached to the bolt thats been welded to the bumper?
i think id like to use your idea as well as my idea as well and use the square headed bolts and weld the bracket to the bumper for extra support.
AND YES I WOULD LIKE SOME PICTURES
dropt72shortbed@aol.com
[This message has been edited by dropped72shortbed (edited March 21, 2002).]
72 c10 swb
