Old 04-08-2004, 02:43 PM   #1
HeavyK20
HeavyK20's Avatar
<<JIMs70GMC>>
How much lift do you have on your rig? What size tires?
I will be replacing springs in my my '69 and I'm looking for a stance about like yours.
Eric
1969 K20, 465/205 package
HeavyK20 is offline   Reply With Quote
Old 04-08-2004, 08:51 PM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Eric, It's a 2" HD tuff country springs up front w/ ORD HD shackles. In the rear I removed the factory block and replaced it w/ a 2" tapered block and added an add-a-leaf from tuff country.
The front sits slightly higher than the rear maybe 1/2". I got about 3" of lift in the front and overall about 2.5" in the rear.
The tires are 33" TSLs, which are about 34" tall, they do not rub. Mounted on 15x10 white wagon wheels. I got the tires because of the load range "D" rating.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 04-08-2004, 10:53 PM   #3
HeavyK20
HeavyK20's Avatar
The pic's of your truck are deceiving, I was thinking you had at least 4" or 5". I'm thinking of going with 2" HD springs all around + a 1" add a leaf. That should give me roughly what you have for lift.
I may also upgrade to the heavy duty hangers on the rear. I haven't figured out why some trucks have larger hangers, but as near as I can tell the 69's have a smaller hanger than 70, 71 & 72. The heavy duty units drop the front of the rear spring about 2" which would add about another 1" of lift.
Eric
Old 04-09-2004, 06:15 AM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I got a good 3" of lift from the front. I talked to Steve @ ORD as I was not expecting that much lift and it's because they are the heavy duty springs, I could make them ez ride by removing the bottom spring, per tuff country.
Also like to add I replaced my body mounts w/ a poly kit, several of my mounts were so compressed you could wiggle the bolts about 1/2" up and down.
Post a pic of the front of the rear spring I'd like to see how the hanger is mounted.
Old 04-10-2004, 12:02 PM   #5
HeavyK20
HeavyK20's Avatar
Here are some pics of the two different hangers.
Eric
Old 04-10-2004, 12:03 PM   #6
HeavyK20
HeavyK20's Avatar
aaa
Eric
Old 04-10-2004, 12:05 PM   #7
HeavyK20
HeavyK20's Avatar
bbb
Eric
Old 04-10-2004, 05:23 PM   #8
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Damn! That is a big difference.
Old 04-12-2004, 09:25 PM   #9
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
never really noticed
here's mine on the 70/71
Old 04-13-2004, 10:06 PM   #10
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Eric, I went out and checked my 70 GMC and it has the shorter mount like your 69. But I believe they compensated for this because before I added the 2" lift my truck had a factory 1" block in the rear. I'm thinking I might look to find some of the longer mounts and get another inch of lift in the rear and give mine a slight rake.
Old 04-14-2004, 08:02 AM   #11
HeavyK20
HeavyK20's Avatar
I had a 70 chevy that had the big mounts. I guess that kills my theory of only the 69's having small mounts.
I wonder if there was some sort of heavy duty option or something?
Eric
Old 04-14-2004, 09:05 AM   #12
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Both my trucks had the HD front and rear spring RPOs on the glove box. Maybe a mid-year switch?
