12-30-2022, 10:04 PM | #1 |
Do all SM465 have the exact same trans-to-bellhousing bolt pattern?
Locdoc saved himself from buying an adapter for his NV4500 swap by drilling holes in his NV4500 case using the original SM465 bellhousing as a "template"
http://67-72chevytrucks.com/vboard/s...d.php?t=673588 Do all SM465 bellhousings have the same trans-to-bellhousing bolt pattern? I have a source on a bellhousing that mated a 350 to an SM465, and I might could use it, rather than having to tear my current trans out first and use it to drill the holes. Thanks everyone. |
12-30-2022, 10:59 PM | #2 | |
The Older Generation
Re: Do all SM465 have the exact same trans-to-bellhousing bolt pattern?
Yes, all small block Chevy SM465 manual bell housings have the same bolt pattern. LockDoc
12-31-2022, 12:34 AM | #3 |
At the body shop.
Depending on your location in California.
I have a loose one you could have for mockup Central CA here
" That didnt make it any newer " " Dont antique the equipment " |
12-31-2022, 01:15 AM | #4 | |
The only thing you have to watch out for is that there are two sizes for the front bearing retainer hole. The small (4-11/16") diameter and the 5-1/8" diameter (needed for the NV4500 transmission). It would need to be a bell housing from a truck with the SM465 manual transmission. (1968 up) LockDoc
12-31-2022, 01:30 AM | #5 | ||
12-31-2022, 01:45 AM | #6 |
At the body shop.
It's here on a shelf
I could measure it in the morning. Mid seventies 454 tho
12-31-2022, 02:36 AM | #7 |
12-31-2022, 02:42 AM | #8 |
At the body shop.
Yep, still do.
Keeps me interested in truckin
12-31-2022, 03:49 PM | #9 | |
The SM420, and possibly the three speed manual transmissions, but I don't know that much about the 3 speeds. LockDoc
12-31-2022, 03:51 PM | #10 |
At the body shop.
Yours for the taking
01-01-2023, 01:14 AM | #11 |
01-01-2023, 06:57 PM | #12 | |
Yes. LockDoc
04-02-2023, 08:08 PM | #13 |
At the body shop.
Good to meet you this afternoon.
Hope the parts work out for you.
04-02-2023, 09:45 PM | #14 |
Good stories man! You son is really impressive for his age. I'll let you know whenever I get the NV4500, hopefully in a couple weeks. They guy made it sound like he has a few lying around, and that I could see them all and pick my favorite. We'll see how many he has in a couple weeks. Thank you for everything.
Here's a pick of my daily, hope I don't get banned for this. |
04-02-2023, 11:46 PM | #15 | |
At the body shop.
Thanks, we really have a good time fixing this old stuff. Good luck with the 4500 project
04-03-2023, 08:58 AM | #16 |
One thing to keep in mind is the bottom two bolts that hold the bellhousing to the main case. Starting in '73 when they went to the cast aluminum bellhousing all four bolts thread into the bellhousing, prior to that the bottom two bolts went from the inside of the bellhousing and threaded into the main case.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
04-03-2023, 09:35 AM | #17 | |
That is correct. You can still use the later bell housings but to install the NV4500 like I did you have to drill out any hole that is threaded. LockDoc
04-03-2023, 09:37 AM | #18 | |
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
04-03-2023, 10:55 PM | #19 | ||
Thanks for the info; I'm a little surprised that such a heavy trans was hung from an aluminum bell... haha. Well looking at your fleet, you seem like a fairly diverse car lover lol |
04-04-2023, 03:53 PM | #20 |
My 52 F-2 is painted 73 Corvette yellow.
