10-02-2012, 10:29 PM | #1 |
Shave steering column shifter
Has anyone shaved the steering column shifter nub off when swapping to a floor shifter. What did you use to fill the hole after grinding/cutting it off. Thanks!
10-02-2012, 10:46 PM | #2 | |
The Older Generation
Re: Shave steering column shifter
I removed the shifter boss and indicator by hacksawing and grinding, cutting a couple of pieces of thin sheetmetal that fit tight in the openings, and JB welding them. Be sure to slip a thin piece of cardboard down inside the collar to keep any JB Weld out of the inside of the housing. LockDoc
10-02-2012, 10:52 PM | #3 |
Hey, Thanks for that!
Did you fit the sheet metal pieces flush with the column, or were they slightly sunk down to hold some JB Weld in the entire opening? |
10-03-2012, 07:24 PM | #4 | |
They were pretty much flush but the metal was a little thinner than the collar. If I remember right I filed a little angle on the opening so the metal wouldn't fall through. LockDoc
10-03-2012, 07:30 PM | #5 |
Thank you!
10-03-2012, 08:44 PM | #6 |
