Old 05-08-2021, 09:04 PM   #1
Asshat
Asshat's Avatar
Need steering linkage help - tie rods, etc.
I installed the 1974 C20 front cross member on my 63 C20, and I guess I didn’t take very good notes on the tie rod ends I purchased.
Can someone school me on how this is supposed to go? The passenger side seems to look ok, but the driver side is not even close.
Can anyone show pics, maybe part numbers for this setup?
And, on the passenger side, should I use the existing bracket to mount the idler? Or use the idler arm from the 74?
1963 C20, small window, long bed
292, 4-speed
Asshat is offline   Reply With Quote
Old 05-08-2021, 10:47 PM   #2
Asshat
Asshat's Avatar
Re: Need steering linkage help - tie rods, etc.
This is the front end before disassembly.
292, 4-speed
Old 05-08-2021, 11:05 PM   #3
Asshat
Asshat's Avatar
I think maybe I have the tie rods at the wrong spot; they should be at the inside of the steering link.
292, 4-speed
Old 05-08-2021, 11:18 PM   #4
KQQL IT
At the body shop.
KQQL IT's Avatar
Our 73
Old 05-08-2021, 11:21 PM   #5
Asshat
Asshat's Avatar
Originally Posted by KQQL IT View Post
Our 73
Ahhh... ok.
Thanks, that helps.
Just what I thought. Hopefully, I can get it assembled tomorrow.
292, 4-speed
Old 05-09-2021, 03:39 PM   #6
Asshat
Asshat's Avatar
Anyone know the best way to position the mount for the idler arm?
Kinda stuck on this.
None of the existing holes line up.
292, 4-speed
Old 05-09-2021, 05:56 PM   #7
Asshat
Asshat's Avatar
I read a few posts and it seems I just need to insure the steering link is level and runs straight across the front cross member; then, I should be able to mark the holes.
Does that make sense? Are there any other considerations?
I may just tack it in place, so I can turn the wheels and make sure it has the proper movement.
292, 4-speed
Old 05-09-2021, 06:12 PM   #8
KQQL IT
At the body shop.
KQQL IT's Avatar
Large C clamp to hold it ?
Old 05-09-2021, 06:50 PM   #9
Asshat
Asshat's Avatar
Holding it in place is not a problem, it’s where to place it.
292, 4-speed
Old 05-09-2021, 08:08 PM   #10
notsolo
notsolo's Avatar
Copy whats in the photo. You have the the brake hose in the elongated hole, line up the rear corner of the flat cut off end with the bottom of the elongated hole. Bottom bolt is close to the lower flange. Get those 2 set and it will be very close. Clamp it off and check your level. and clearance in front of the cross member.
notsolo is offline   Reply With Quote
Old 05-10-2021, 02:11 AM   #11
Asshat
Asshat's Avatar
Isn’t the brake hose supposed to go there, in the elongated hole?
There’s no other hole for the brake line to go into.
292, 4-speed
Old 05-10-2021, 04:00 PM   #12
KQQL IT
At the body shop.
KQQL IT's Avatar
Our 68
Old 05-10-2021, 04:10 PM   #13
KQQL IT
At the body shop.
KQQL IT's Avatar
Try and straighten them up.
I don't know why these flip randomly
Old 05-17-2021, 12:52 AM   #14
Asshat
Asshat's Avatar
Ok, I have two questions, which will probably lead to more questions later.
1. Is there a procedure for adjusting or lining up the linkage? Since everything was totally disassembled, I’m not sure where to start. I’m planning on taking it to a front end shop for an alignment right away, but I will need to drive it there.
2. Is the pressure port connection on the steering gear the larger port?
292, 4-speed
Old 05-17-2021, 01:48 AM   #15
KQQL IT
At the body shop.
KQQL IT's Avatar
Make sure the center link Is correct.
Center up the pitman and idler arms.
Get the tie rods similar lengths.
Put about 6 shims in the front and 3 or 4 on the rear studs
Then set the toe in close ish
Can't help with the p/s
ditched mine for a manual box
Old 05-17-2021, 04:51 AM   #16
Asshat
Asshat's Avatar
Why did you remove your power steering?
292, 4-speed
Old 05-17-2021, 10:44 AM   #17
KQQL IT
At the body shop.
KQQL IT's Avatar
Because it decided to dump its fluid all over my garage floor and had a NOS manual box.
It's mildly inconvenient at times but doesn't bother me enough to put it back.
Old 05-17-2021, 11:37 AM   #18
Asshat
Asshat's Avatar
I get it; I like the simplicity, however, maneuvering in parking lots is a PITA.
292, 4-speed
Old 05-17-2021, 01:00 PM   #19
KQQL IT
At the body shop.
KQQL IT's Avatar
Super simple.
Manual steer
Manual brakes
1 wire alternator
Old 05-18-2021, 02:52 PM   #20
SCOTI
SCOTI's Avatar
Super simple.
Manual steer
Manual brakes
1 wire alternator
Manual steer & brakes I get. 1-wire alt I don't.
Why would it be better vs. common off the shelf replacement units available almost everywhere?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-18-2021, 06:05 PM   #21
KQQL IT
At the body shop.
KQQL IT's Avatar
3 less wires under the hood
And was a easy way to get a 140amp alternator in original brackets.
And tied the trigger wire up under the distributor if it's ever needed.
Old 05-21-2021, 01:33 AM   #22
Richard
If you take pics on phone and do not want to edit them on computer, always hold phone vertical when taking the picture. If you upload to computer and have windows. Simply open the pics with paint and save them. I have found it prevents the turning. You can preview the post as well before posting to see if pics are correct.
Richard
