Old 09-21-2002, 03:10 AM   #1
sevenwonder
Question Lower A-arms
Is the lower a-arms the same on a 69 1/2 ton with drums as to a 72 1/2 ton with disc? both 2 wheel drive.
Also is it correct that the sway bay will fit from the 69 to the 72.
70 short,step on a 72 frame.
sevenwonder is offline   Reply With Quote
Old 09-21-2002, 03:49 AM   #2
Fast68Chevy
Fast68Chevy's Avatar
the big steering stops welded to the lower arms will probably ot be locate din same place from a 69 to a 71, a tape measure will tell you that or not.
no other differences however, and 73-up arms with the rubber bushings will bolt under your truck too
and any sway bar up through 1 ton will bolt onto your truck from '64-87
not van ones though
happy swapping
Fast68Chevy is offline   Reply With Quote
