Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 07-31-2012, 10:33 PM   #1
68 GMC step long
68 GMC step long's Avatar
Red Rocker 72 GMC Jimmy
This is my dads 72 Jimmy that he got arround 16 years ago and has been sitting in the garage since. After we restored my 68 GMC step side long box for my high school graduation hes been wanting to get at it and with my help we started it today. It had a 305 small block and a 350 trans that will be uprgaded to a 496 big block and a 400 turbo. Today we put new body mounts and heavy duty leaf springs in the front axle.
68 GMC step long is offline   Reply With Quote
Old 07-31-2012, 10:53 PM   #2
72Blazing
72Blazing's Avatar
Re: Red Rocker 72 GMC Jimmy
Nice solid tub. This should be a really nice ride when finished!
72Blazing is offline   Reply With Quote
Old 08-08-2012, 09:45 AM   #3
68 GMC step long
Well we had a productive weekend and got the front clip on. As well as getting the doors all welded up and every thing is fiting nice. When we replaced the front leaf springs last week we found that the left bolt that holds the springs together at the axle was broke. And now we cant get the core support to fit right with the mounts in. It sits up too high. So we figure that the truck has been jumped before. So before we take it back appart we willl have to put it on the frame rac and get the frame straightend. For the people who notice the right fender is for a chevy and we are just useing it untill we get a gmc fender.
Old 08-14-2012, 09:10 PM   #4
OLD K5
OLD K5's Avatar
Looks good. Keep up the good work.
OLD K5 is offline   Reply With Quote
Old 08-16-2012, 08:42 PM   #5
68 GMC step long
Unfortunately my dad either has tennis elbow or has a torn something. So not much progress has been made lately. We did get the new wheels and tires today that will be on the Jimmy. They are Cooper AT3's 315-75-R16. Which is like a 35-12.5-R16.
Old 08-16-2012, 09:03 PM   #6
swyfor5
swyfor5's Avatar
Gotta love that chevy orange on the motor!
swyfor5 is offline   Reply With Quote
Old 08-17-2012, 05:20 PM   #7
fear_nothing
fear_nothing's Avatar
Good choice on the rims
fear_nothing is offline   Reply With Quote
Old 08-26-2012, 07:30 PM   #8
68 GMC step long
Last week we got the fender on the passenger side that we will be using. And we put the new tires and rims on it. Then we pulled the front clip and bolted the 496 big block, 350 trans and transfer case together. We put the assembly in the jimmy and found out that it didn't fit....
Old 08-26-2012, 07:43 PM   #9
68 GMC step long
We started cutting the firewall this weekend and got the motor to fit. We still have to finish the firewall off but it's close. Had some other issues with the a/c compressor but we have that problem almost fixed. We will just have to get a longer belt.
Old 10-03-2012, 12:38 PM   #10
68 GMC step long
Finally got some time to work on the jimmy. We got the doors fitting well and the front clip is also. We pulled the body and put it on a rotisorry and powerwashed the frame and put that on our frame rac.
Old 10-04-2012, 01:40 PM   #11
99-LS1-SS
99-LS1-SS's Avatar
What motor mounts did you use?
My 1972 2WD Blazer build
1984 K10 beater truck
99-LS1-SS is offline   Reply With Quote
Old 10-06-2012, 02:26 PM   #12
68 GMC step long
Factory style. Parts Master #2282. Car Quest # 31-2239HD. We are going to cable the motor to the frame also. Here are pictures of the old ones.
Old 10-07-2012, 05:45 PM   #13
68 GMC step long
Went throu a LOT of sand this weekend. Frame, crossmembers, axles and trailer hitch all clean and in the spray booth.
Old 10-08-2012, 11:18 AM   #14
99-LS1-SS
99-LS1-SS's Avatar
I apologize for asking my question the wrong way. Did you use the truck big block frame stands or the small block frame stands?
Old 10-08-2012, 05:47 PM   #15
68 GMC step long
I believe the small block frame stands. We were unaware of there being a difference. It had a 305 small block originally.
Old 10-08-2012, 05:54 PM   #16
68 GMC step long
Dad got the frame all painted today. Found a broken leaf in the right rear spring. So we will go to our local spring shop and see about getting just the one leaf replaced and doing the same one on the other side.
Old 10-13-2012, 09:16 PM   #17
68 GMC step long
Rolling chassis.
Old 10-14-2012, 11:55 AM   #18
Slinger60
Slinger60's Avatar
Looking real nice.
1969 C10 LWB GMC.
1970 K5 Blazer
1971 K10 Burb
Build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=529970
Shawn
Slinger60 is offline   Reply With Quote
Old 10-14-2012, 08:54 PM   #19
68 GMC step long
We got the t-case painted and put the motor, trans and t-case on the frame
Old 11-23-2012, 08:37 PM   #20
68 GMC step long
Painted fire wall and got the frame back from the guy that did the exhaust. 3 in. stainless steel.
Old 11-23-2012, 08:45 PM   #21
68panelman
68panelman's Avatar
Good stuff. Keep up the great work!
68panelman is offline   Reply With Quote
Old 11-30-2012, 12:01 PM   #22
hgs_notes
GEARHEAD
hgs_notes's Avatar
That is one of the prettiest exhaust systems I've ever seen. This is going to be a nice truck. Will you have any problems with the under dash heater box with the firewall modifications you made? Or with the gas pedal installation?
hgs_notes is offline   Reply With Quote
Old 12-08-2012, 03:02 PM   #23
68 GMC step long
Sorry this took so long. Been really busy. Thank you for the complament. The gas pedal will be about an inch closer. And the heater/ac box wont have any issues. We mocked it up when we were cutting so we knew how far we could go. And the center of the fire wall wasnt cut so that part is still at the factiory location.
Old 12-08-2012, 03:12 PM   #24
68 GMC step long
The body is back on the frame and we got the motor runnig. It sounds so goood.
Old 12-08-2012, 05:52 PM   #25
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
Looks sweet!
1978 C3500 Crewcab (Project)
1979 C2500 Crewcab (Driver/project)
1988 R2500 Crewcab (Driver)
1988 V3500 Crewcab
1988 R2500 Crewcab (Mint, Ex Fire Dept)
1968 Chev Suburban (4x4 conversion) LINK
1970 Chev C20 Suburban (driver/cruiser)LINK
2005 Impala (Incognito vehicle)
2004 Yukon XL Denali (Kid hauler)
1947 Case tractor
Facebook Page(1000's of pictures of GM cars and trucks organized into albums)
YouTube Channel
Mr Pops is offline   Reply With Quote
