10-26-2020, 11:30 PM | #1 |
New Crossmember for a 62
Check out this beauty! My new auto trans crossmember for my 62 C10
Courtesy of Capt Fab of course. No way I could pull this off! No excuse now, time to complete the mock up and get this installed. |
10-27-2020, 09:56 AM | #2 |
Re: New Crossmember for a 62
Nice work!! CaptainFab is amazing....
10-27-2020, 10:00 AM | #3 |
What transmission are these designed for? Are they for SWB ? Very interested in knowing details - it looks great!
10-27-2020, 10:27 AM | #4 |
He earned is handle with that one!!!
10-27-2020, 05:46 PM | #5 |
1962 C-10
That's friggin awesome! C-Fab is the man!
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
10-27-2020, 08:18 PM | #6 |
Nice !!!
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
10-27-2020, 09:01 PM | #7 |
Yes, it's for a SWB C10. I'll be running a TH350, but it will fit the TH400 as well and I think a couple others.
I think this will more than handle anything I can throw at it! Great quality |
10-27-2020, 09:03 PM | #8 |
Ya it's a beautiful piece of work!
10-27-2020, 10:20 PM | #9 |
60-66 Nut
Thanks for all the compliments
11-05-2020, 10:36 AM | #10 |
Ok, can this be true? A TH350 crossmember for a '62??
Will this still fit with the torsion bars in place? The PO of my '62 did a hokey job with the 350/TH350 install and I need something more reliable.
When was the last time you did something for the first time? We never really grow up, we only learn how to act in public. |
11-05-2020, 10:17 PM | #11 |
Absolutely true! I have not installed it yet but I've held it in place and it fits great. I'm hoping to do a mock up this weekend if it doesn't rain.
You won't go wrong with Captain Fab. Never seen a complaint about any of his products. |
11-06-2020, 10:57 AM | #12 |
I totally agree!
I have his power steering bracket as well as his power brake bracket. Perfect fit. BUT - will this crossmember fit with your torsion bars in place?
11-06-2020, 11:40 AM | #13 |
It should - the torsion bars are on the outside of the X, aren't they?
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
11-06-2020, 03:20 PM | #14 |
Nice! CaptianFab do you think it will work for a T5 trans?
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
11-06-2020, 10:49 PM | #15 |
60-66 Nut
It will work with a T5 if the mount is in the same location as the Powerglide and TH350 relative to the back of the engine.
Yes the trans mounts I have made will work with the torsion bars in place. This crossmember is patterned after a factory Powerglide crossmember. The torsion bars are below it. The crossmember Todd46 has is not the first one I have fabricated.
11-07-2020, 09:07 AM | #16 | |
11-07-2020, 10:04 PM | #17 |
Got it installed today. Fits like a glove. Mounting holes lined up perfect. Had to drill the top hole in my frame but the lower two matched up like OEM.
Here's a couple pics so you can see the relation to the torsion bars. Even painted it up pretty so you can see it! Sorry they're sideways |
11-07-2020, 10:47 PM | #18 |
60-66 Nut
11-08-2020, 10:12 AM | #19 |
Straightened
11-08-2020, 12:32 PM | #20 |
Thanks!
11-08-2020, 07:22 PM | #21 |
You bet
11-10-2020, 10:30 AM | #22 |
Yes, I believe you are right.
10-12-2021, 12:24 PM | #23 |
Hey Captain, a couple of quick questions on this 62 rear crossmember - does this bolt into existing holes in the frame? Can this be installed while leaving the original manual transmission crossmember in place? I'm putting in a Saginaw 3 speed using the original rear bellhousing mount and have seen comments that suggest the Saginaw should be supported in the rear - the transmission has a rear mounting boss. If I install this for the 3 speed, will it be in the right place for an automatic if I go that route down the line? Going into a 62 short bed. Thanks for your help.
10-17-2021, 10:01 PM | #24 | |
60-66 Nut
Yes the trans crossmembers that I am fabricating does bolt into the original factory location using the factory holes, plus one more on each side that needs to be drilled. I patterned them after the OEM auto trans crossmembers. IMO you do not heed an additional crossmember on the rear of a Saginaw 3 speed. GM installed them just hanging off the back of the bellhousing. In fact having too many mounting points can cause binding and breakage. If you really feel you need one, I have one welded up and ready to ship.
