06-08-2024, 10:08 AM | #1 |
60-62 V8 throttle linkage
Im in the middle of a V8 swap. What can I use for the throttle linkage? I still want to use the original pedal assembly but the adjustment rod on the end is to short. I found a 63-66 throttle pivot not sure it will work with the 60-62. Any advice would be helpful.
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
06-09-2024, 11:42 AM | #2 |
Re: 60-62 V8 throttle linkage
When I swapped in a carbureted V8, I found the V8 throttle linkage rod, but went to the 71-72 cable throttle & pedal because of concerns with proximity to distributor wires. The cable setup is much smoother and no moving parts next to distributor. Had to change the pedal, but not really concerned since it works so well. Cable can be found by doing a little research on lengths or just cutting the housing and crimping an end on. Good luck!
06-09-2024, 01:52 PM | #3 | |
