![]() Join Date: Jul 2015
Brake line kits for conversion disc
Do the brake line kits work for these truck when converted to disc brakes?
Is there a company that sells pre-bent sets?
1963 C20, small window, long bed 292, 4-speed |
Moderator
![]() ![]() Join Date: Aug 2011
Re: Brake line kits for conversion disc
Stainless - https://www.performanceonline.com/19...less-Material/
OEM type - https://www.performanceonline.com/19...-OEM-Material/
#3 | |
I found it’s easier to bend NICOPP line than install a pre-bent kit. It’s easy to bend and flair, and maybe cheaper
Moderator
True. I like doing my own.
#6 | |
![]() Join Date: Oct 2017
Has anyone purchased and installed the performance online disc brake and drop spindle kit? I am currently pricing this out with western chassis and CPP and this kit is much cheaper. Wondering about quality, etc.
Moderator
Mine is POL. Works well, great quality, mine is like 5 years old. I just got it on the street this year. 500 miles today.
![]() ![]() ![]() Join Date: Jan 2018
I have the POL kit on my truck, but I got stock height spindles instead of drop spindles. I've had the kit on the truck for over 5 years now. It has worked well for me, and I haven't had any issues with it. I don't know exactly how many miles over the years, (broken odometer for a couple years) but I wouldn't be surprised if it's over 20k
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
Do you guys think the front disc upgrade is worth the money? I have been hemming and hawing because I feel with only a 250 in it that it stops pretty good with the drums. I drive pretty tame in it.
Moderator
I wouldn't drive with drum brakes myself. But there are people who swear by them so it depends on who you ask.
![]() Join Date: Sep 2020
Agree with Rocknrod, sometimes newer technology is very welcome….
#13 | |
I have one truck with front disc and one with drums. (Both are non boosted.) Truth is, on relatively flat gound they stop about the same unless the brakes get hot. It's the hard driving on summer days especially on curvy mountain roads where the discs really pay off. I keep the drums truck away from congested thruways and steep moutain grades (It's basically a stock truck) and it's fine. Last edited by AcampoDave; 12-12-2021 at 11:59 PM. Reason: More info added |
Got another related question. When y'all changed to front disc, did you change out the suspension bits? As in the ball joints and tie rods? Mine don't look to bad and that would add another $600 bucks to the costs.
I mean how far does one go lol. |
#15 |
You go till you feel safe with the parts that you life and lives of others depends on, safety doesn’t necessarily come cheap….your call
#16 | |
Only thing I would do different is that I would probably do everything all at once so that I wouldn't have to pull it apart again, and I definitely should have taken the time to paint everything when it was all apart the first time
#17 | |
At the very least, if you decide to keep the drums, upgrade the master cylinder to a dual line from a 67 truck if you haven't already done so
#18 |
Yah I was actually thinking on upgrading to a Wilwood Master Cylinder regardless of what I do. Funny (or not so funny depending) when I hit my brakes hard which is rarely my rears lock up and screech really loud at times. I imagine since theres no weight back there.
