10-26-2008, 11:00 PM | #1 |
Dolphin Quad Gauges - Not Recommended
If you are considering Dolphin for a set of 5 inch quad gauges you might want to consider my experience. I installed a set last July in my 54 Chevy and noticed on the first night ride the illumination between the two buckets was significantly different with the speedo nice and bright and the gauge bucket very dim. Thinking I had wiring it incorrectly I checked everything and confirmed my grounds. Everything checked out. I contacted the Dolphin Tech line and was informed they were aware of the problem and were working on a new gauge bucket with brighter lighting. I was told to call back in a month and they would swap the unit I had out with a new one. Sounded good to me.
Two months later I called to see if the new buckets were available and was informed they will not be fixing the problem and they suggested I wiring in a resistor to reduce the lighting level of the speedo to match the gauge bucket. This is not an acceptable solution to me. If the problem had been know going into the purchase I would not have selected this product. I requested they buy back gauges from me or refund my purchase price to which I have not received a reply. I have attached a pic of the gauges at night. While the gauges can be read it is not as easy as the speedo which is obvious. If you would be happy with this level of lighting or only drive during the day then these might be the instruments for you but to me they are a second rate product which will be included in my next swap meet material. Last edited by N2TRUX; 03-07-2013 at 10:59 AM. |
11-07-2008, 03:41 PM | #2 |
Re: Dolphin Quad Gauges - Not Recommended (UPDATE)
Wanted to provide an update to this:
I have had an email discussion with Dolphin regarding this problem. Seems it got the attention of someone high enough on the ladder to give a green light to corrective action. I think it bodes well they are doing something positive to address the issue instead of shooting the messager. If the fix solves the problem I will be back to let you know. |
11-08-2008, 12:07 PM | #3 |
mini truck racer
Please keep us updated on this . I just bought a set for the 49' and have not even opened the box .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
11-16-2009, 03:32 PM | #4 |
After giving this company many opportunities to correct the problem either by providing me with a new gauge bucket with updated lighting or refunding me some of the initial cost I am tossing in the towel.
Since I made my initial post I contacted Dolphin several times. Each time I was told the fix was in process. The Fix has never been done. Their 5" quad gauge is a poor product. The company knows of the problem but continues to sell it. Please do not waste your time and money as I have by dealing with this company. It is a shame that the magazines continue to take this companies dollars for advertising. I guess they do not care about us either and just want the money. |
11-26-2009, 09:11 AM | #5 |
That's odd a company that won't stand behid there products.If they won't fix it you could try adding some leds to it should work.
11-26-2009, 05:09 PM | #6 |
Its a Truck Thing......
That sucks,
I was considering picking up a set. Thanks for the review. Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
11-27-2009, 10:43 PM | #7 |
low n' slo
man that sucks. i wonder how they even make the lighting that far off, knowing as soon as its on it will be noticeable. good luck to ya
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
12-03-2009, 04:53 PM | #8 |
Now what??
Has anyone had any problems with the AutoMeter quads? Just curious.. I am going with a quad set up- but NOT Dolphin!
69 Long Fleet - Project 06 Ram 1ton Cummins 4x4-DD 01 Tahoe- wifes "The quality of a persons life is in direct proportion to their commitment to excellence, regardless of their chosen field of endeavor." ~ Vince Lombardi "A dream doesn't become reality through magic, it takes sweat, determination and hard work." ~ Colin Powell my, um, build USMC OIF Veteran SEMPER FI!
12-25-2009, 03:32 PM | #9 |
Man that sux, I was planning on using those gauges in my truck but guess I'll look for something else. Glad I found this post, I should be ordering some soon
12-26-2009, 06:05 PM | #10 |
Moderator
Wow Houston! Your original post was a year ago. You have way more patience than I do.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
12-15-2010, 11:16 AM | #11 |
Since I have seen several people opting to use these guages during the past year I thought I would give this a bump in the hope others who may be thinking of using these guages will be aware of the problems.
05-24-2011, 06:20 PM | #12 |
btt
05-24-2011, 06:45 PM | #13 |
Active Member
Thanks for bumping this up...I always thought Dolphin made a nice looking product, and I am half-heartedly looking for some gauges to replace a set of Autoloc gauges I'm not entirely happy with. I will take this into consideration on my next purchase.
Maybe direct them to this thread? If they see enough people are changing their mind because of it maybe they will do something about it?
1957 GMC Ambulance 1962 Belair Wagon 1963 C80 Truck Cab *FOR SALE* 1969 Chevy C10 Short Bed 1972 Chevy C10 Long Bed *SOLD* 1996 C3500 Dually *SOLD* |
05-25-2011, 11:07 AM | #14 |
I have used Dolphin gauges for over 6 years, I have always been satisfied with their quality. I dont particularly care for their customer service just because talking to someone or getting emails back in a timely manner is like flossing alligator teeth. I have had a few issues with a guage here and there, they have always sent a new one without question, all though I didnt know they did until I get a package at my door.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
05-25-2011, 09:31 PM | #15 |
Has anyone used the 5 or 6 gauge sets ? The price is close to VDO 5 gauge set for a 6 gauge Dolphin or Shark set
05-26-2011, 05:39 PM | #16 |
I have both. a 6 guage and a 5 guage, both work fine.
05-27-2011, 09:22 AM | #17 |
This thread is specific to their 5" quad set. I do not have any opinion about any of their other products other than based on my current experience I would look elsewhere first.
This company is aware of this thread and others I have posted on similar sites. I am only sharing my experience with this company and with this specific product so others can be aware of its shortcomings. The gauges have worked well for the 3 years and 37K miles I have been running them and fortunately most of those miles are in the day light. They have my contact information and have opted not to make an effort to resolve my issues with this product. |
05-29-2011, 07:32 AM | #18 |
05-29-2011, 08:07 PM | #19 | |
Living In The Past
I dont care if they have "some" good products. Customer service means a lot to me. I had looked at their line of gauges but after seeing this thread without any attempt by Dolphin to respond , I sure wont be doing any business with them. after telling the OP to wire in a resistor, at the very least they should have sent said resistor with wire harness if that is their fix Last edited by Olden Days; 05-29-2011 at 08:24 PM. |
05-29-2011, 02:37 PM | #20 |
wiring procedures? they are pretty straight forward, what are you looking for exactly?
06-01-2011, 05:26 PM | #21 |
Junior Member
emailed the company
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
09-27-2011, 08:57 AM | #22 |
I was also considering gauges from Dolphin.
After reading this thread I sent them an email. Their reply to me was that the light issue was only an issue if using a programmable speedo and it was not an issue if using a mechanical speedo. Iwonder if that is the underlying problem for real? scott |
09-27-2011, 09:31 AM | #23 | |
Just a car guy
Way to dim for night driving imo.
1955 belair Blown Pro Street cruiser 1971 Camaro Pro Touring 1973 Vega Drag Car 1970 C20 tow rig |
10-04-2011, 08:56 PM | #24 |
78K & 79C Jimmys
heck one looks yellow and one white
way to dark..... not gona buy that one
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
10-14-2011, 06:37 PM | #25 |
Bump.....Glad I found this, was going to go with Dolphin Gauges!!!
