Still Learning
Original Bucket seats installation????
I'm trying to drill the holes in my cab for original bucket seats. I'm looking for some pictures of the braces and alignment of the seats. Anyone document their installation? I have the material to make the braces but would kinda like to see some originals.
Are the outside front holes used on LH and RH seat mounts? Thanks |
Still Learning
Re: Original Bucket seats installation????
Here are some pictures of what I'm looking at.
Notice that the seats are touching the center console on the sides with the bolts in the outer stock bench seat holes. |
![]() Join Date: Oct 2009
subscribed. Always thought they used the same holes as the bench seat - so, therefore, I have no clue.
Still Learning
I have always thought that too but, it just doesn't look right. The driver side inside mount hits the tranny tunnel raised area before the bolt will fit in the hole too. I can force it in there but it's tight.
if you look there are dimples in non bucket seat floors for bucket seat location. There are also dimples in the center floor pan for the console as well. The only direct bolt in is the the buddy bucket seats, all others must be drilled to fit.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
![]() Join Date: May 2010
I don't have my cab here to confirm this, but it appears that the dimples refered to are visible in a couple of your pictures outboard of the seat brackets. Looks like 1/2"-3/4" out from the existing holes. This is consistent with where my original buckets were mounted from the factory.
#7 | |
Still Learning
These look like dimples in the picture here:
Mike "69 Short Wide" My Project 86 Silverado Landen's Project Instagram: @mcbassin My Website C/10 Club Oklahoma Facebook Group Last edited by mcbassin; 03-25-2012 at 11:45 PM. |
Those are the ones I was referring to. I don't have any pictures that would help, and the truck is currently disassembled and 2000 miles away. If you can wait about 3 weeks I can get pics. However, I estimate the seats are about 3/8"-1/2" away from the console. I have some shots with the seats installed but from a 45 degree angle... not much help.
#9 | |
Still Learning
#10 | |
Still Learning
Any chance any of you experts have some pictures of your original buckets or a measurement from the seat bracket to the center edge of the radius? |
#11 | |
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Still Learning
Okay, I bit the bullet and went with Mel's suggestion from the original bucket seat floor pan. Although I didn't build the brace that ties the two sides together I did make some braces from some old ball bearing drawer slides. They are the exact thickness and near the same width and depth. Here are the pictures of what I did in case someone else can use it. If you look at the pictures, you'll notice I moved the driver side hole pattern outward 3/4". this made the two seats the same distance from the edge of the seat to the door opening symetrical. It also made it where the driver side seat isn't bound up against the console.
Mike "69 Short Wide" My Project 86 Silverado Landen's Project Instagram: @mcbassin My Website C/10 Club Oklahoma Facebook Group Last edited by mcbassin; 03-27-2012 at 12:43 AM. |
Still Learning
More pictures
very helpful - thanks for posting (everyone) - answers some questions I've had for a while also.
The pics are worth a thousand words, as they say... ![]() |
#15 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Another great post to keep seeing I'm 90% sure I'm getting buckets and console for Pinky.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#16 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Great work on the underside reinforcements!
#17 |
Still Learning
Thanks Keith.
Thanks to all you guys the helped me figure this out. That's the stuff that makes this board great ![]() |
#18 |
Eat, Sleep, Drive a Chevy
nice work Mike
I am going to keep this one for future refrence
Trey Silence may be Golden, but Duct Tape is Silver! 72 Short Step 57 "big window" short step |
#19 |
I will add that the big middle brace can be found and removed from any early blazer, got mine from teeitup. Randy usually cuts them out when he parts out a blazer. If you get this piece you can use it as a template to drill the front holes in the correct location and then either use panel adhesive or weld it in. This piece really takes all the guess work out of where the holes should be.
Jeff Posted via Mobile Device
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
#20 | |
SWB 4x4 Collector
![]() Join Date: Jun 2001
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
#21 |
Man of Mini-Talents
Hey Mike,
On mine, I used the outside front holes and then marked the locations with a Sharpie so I would have the locations exactly right with these seats. In the process of drilling I noticed the dimples that others have seen. Anyway, I went ahead and used the outside fronts as they would be more secure than what I rigged up, and the console just barely touches the seats at the front corners. Not snug at all. *shrug*
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
#22 |
NICE work mcbassin!
project: "my happy mess" |
#23 |
Laid Back
![]() Join Date: Apr 2010
Looks good mike!! I think you have more than enough bracing!!
72 chevy swb Direct dealers for.. Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body.. Kyle http://67-72chevytrucks.com/vboard/s...d.php?t=574629 |
#24 |
Man of Mini-Talents
Start spinning off some sets Mike. The line forms behind me, guys.
#25 |
Subscribed...I'm gonna need this info too
